How can I get a URL from a bunch of code?
Guest
Jan 23, 2007 Jan 23, 2007
Hello,
I am performing a cfhttp (get) and it is returning the contents of a webpage. At the top contains the following code in the <head> tag:
<head><title>You have new Picture Mail!</title>
<!-- lsPictureMail-Share-aEAr4d7TmUP9t8s8L08x-comment
&lt;?xml version=&quot;1.0&quot; encoding=&quot;UTF&#45;8&quot;?&gt;
&lt;shareMessage&gt;
&lt;messageContents type=&quot;PICTURE&quot;&gt;
&lt;messageText&gt;This is a test&lt;/messageText&gt;
&lt;mediaItems&gt;
&lt;mediaItem id=&quot;1&quot;&gt;
&lt;title&gt;&lt;/title&gt;
&lt;url&gt; http://yyyyyyyy.xxxxxxx.com/getMMBOXMessageMedia?id=Xw1004H8sLv6S3x76lVPYmsnJP2O20g3G1ktos3o40eowQu2...
&lt;urlExpiration&gt;2007&#45;01&#45;29T19:44:23Z&lt;/urlExpiration&gt;
&lt;/mediaItem&gt;
&lt;/mediaItems&gt;
&lt;/messageContents&gt;
&lt;/shareMessage&gt;
<!-- lsPictureMail-UserInfo-aEAr4d7TmUP9t8s8L08x-comment
&lt;UserInfo timestamp=&quot;2007&#45;01&#45;22T19:44:23.414+00:00&quot; originating_from_address=&quot;test@pm.sprint.com&quot;&gt;&lt;credential name=&quot;MDN&quot;&gt;3333333333&lt;/credential&gt;&lt;/UserInfo&gt;
</head>
What I need to do is extract items like the URL, subject and originating_from_address. Would anyone suggest the best way to do this????
Thanks!!
Advanced techniques
654
Deleted User
Thank you for all of your help. I think I figured it out. Here is what I did for anyone else that might run into this issue.....
<cfsavecontent variable="thisstring">
#cfhttp.filecontent#
</cfsavecontent>
<cfset blah = REFindNoCase("THIS_IS_THE_BEGINNING(.*)THIS_IS_THE_END", thisstring, 1, True)>
<a href="#mid(thisstring, blah.pos[2], blah.len[2])#" target="_blank">Click to view Picture</a>
If the document is well formed XML you can use the XML capabilities of
ColdFusion, otherwise you will probably want to use regex functionality
to find what you are looking for.
Guest
Thanks for replying. It really is not a well formed XML layout. It is in the header tag of an HTML page.
What I am doing is processing images that are sent in from mobile phones. It is all based on the carrier and some just send as an attachment while others send a branded webpage.
What is regex functionality??
Regular Expressions - a syntax used to parse strings. One uses the
refind() and rereplace() functions in ColdFusion to utilize this syntax.
http://www.regular-expressions.info/reference.html
Guest
I am trying to use the "Start of String and End of String Anchors" to find the URL in the following section -
&lt;url&gt; http://pictures.sprintpcs.com/getMMBOXMessageMedia?id=Xw1004H8sLv6S3x76lVPYmsnJP2O20g3G1ktos3o40eowQ...
I am trying the following cfset ......
<CFSET tekst_striped = refind(cfhttp.filecontent, "^&lt;url&gt; http://*&lt;/url&gt;$","THIS IS THE ENTIRE URL")>
where ""^&lt;url&gt; http://" will find the start anchor and "*&lt;/url&gt;$" will be the end anchor. Would you say I am on the right track???
On the right track, but not quite there yet. But I am not enough of an
regex expert to help you much further.
You may get better help from a regex focused list. One I have used
before is the regex list at houseoffusion.com or the more general cftalk
list at the same site.
Guest
Also, I am running CF 5.
I am not sure what you are looking for but try the following to see if you can see the information you are trying to retrieve:
<cfdump var="#getHttpRequestData ()#" label="HTTP Request">
<cfdump var="#CGI#" label="CGI">
The first will show the content of the HTTP headers. The second will show you a structure of CGI variables that contains things like script name.
Cheers
Guest
Thanks. I tried that and it returned the vairables of the process page from our server. I use cfpop to get the emails that are sent in from mobile phone. Here is all the code from the page that is sent to me:
(attached)
Do you see the variables in the <head> tag? That is the information I need. Do you have any other ideas?
Thank you so much for your help.
Guest
I'm sorry, here is the right code with the variables in the head tag......
Guest
</cfsavecontent>
Documentation
