Show 4 replies
1. Re: Monitor color is off - can't calibrate?
Mark Mapes Dec 8, 2008 11:54 AM (in response to lchapman66)What's the make/model of your computer, what graphics card is installed, and what's the date of the graphics driver? -
2. Re: Monitor color is off - can't calibrate?
lchapman66 Dec 8, 2008 12:45 PM (in response to lchapman66)HP Pavilion ze2000
120Gb HDD
1Gb RAM
Intel 82852/82855 GM/GME Graphics Controller
Driver dated 6/17/2004
As I mentioned before, OnLocation CS3 runs fine, and CS4 seems to work fine except for this issue. -
3. Re: Monitor color is off - can't calibrate?
Mark Mapes Dec 8, 2008 3:54 PM (in response to lchapman66)As I suspected, your graphics card does not support Pixel Shader 2.0, which became a requirement with OnLocation CS4.
If the behavior is the same as on other systems with a sub-spec graphics card, I believe you'll find that for the same reason the scopes (Wf Mon, Vectorscope, Histogram) are not working properly, either. -
4. Re: Monitor color is off - can't calibrate?
lchapman66 Dec 8, 2008 6:13 PM (in response to lchapman66)No budget for a new laptop right now. Looks like I stay with the CS3 version.
