I am using a simple Flash program with 4 lines of text -- the
final line being a company name -- for the header of a website. The
program works great. Current the text is dynamic with the text held
in a flash.txt file linked to the flash.fla file.
In place of the final line of text in the program, I would
like to substitute a graphic logo. The graphic I want to use
instead of text is basically the same size as the text. And I I
don;t need to change the animation text. I just want to be able to
use the graphic instead of the simple text. Is there is a simple,
easy way to substitute the graphic flie (say, a gif, or png file)
to the text in the flash program? I am assuming that this should be
easy, but I can't figure out howto do this (yes, I am relatively
new at this). Can anyone give me any suggestions, clues, or insight
into how to do this? Thanks very much for you help.
Thanks.
