You're not calling the COMPONENTS, you're calling the methods
within the
components, which are all different. So if you need all those
methods
called, then yes, you... do... have to call them.
You could cut down the number of keystrokes and make your
code more
readable if you used CFScript instead of CFML, eg:
<cfinvoke component="#Students#" method="ListStudents"
returnvariable="ListStudents" argumentcollection="#Form#">
becomes:
ListStudents =
Students.ListStudents(argumentcollection=Form);
The other thing you could do is to to write one more method
called
doesItAll() (or something), in which you stick all that code,
and
doesItAll() takes only those few arguments needed to all
those method
calls, and returns one struct with all the results in it:
stResult = Students.doesItAll(argumentCollection=Form);
<cffunction name="doesItAll" returntype="struct"
output="false">
<cfscript>
var stReturn = structNew(argumentcollection=arguments);
stReturn.ListStudents =
ListStudents(argumentcollection=arguments);
stReturn.GetAddress =
GetAddress(argumentcollection=arguments);
stReturn.GPA = GPA(argumentcollection=arguments);
stReturn.Education =
Education(argumentcollection=arguments);
stReturn.GetComments =
GetComments(argumentcollection=arguments);
stReturn.Academic = Academic(argumentcollection=arguments);
stReturn.LSAT = LSAT(argumentcollection=arguments);
return stReturn;
</cfscript>
</cffunction>
(note: this omits the call to the "image" component, which
would still need
to be done separately)
Adam
