I use a PdfStamper to customize an existing pdf. And I add a PdfPTable with the writeSelecteRows method.
It worked fine in CFMX7 but when I upgraded to CF8.
I have an exception with this methode: Use PdfStamper.getUnderContent() or PdfStamper.getOverContent()
The code is :
//create the output file
fileIO = createObject("java","java.io.FileOutputStream").init(newFile);
//load the template PDF with the iText PDF reader
reader = createObject("java","com.lowagie.text.pdf.PdfReader").init(pdfFile);
//load the template into the iText PDF stamper and specify the output file
stamp = createObject("java","com.lowagie.text.pdf.PdfStamper").init(reader, fileIO);
over = createObject("java","com.lowagie.text.pdf.PdfContentByte");
over = stamp.getOverContent(javacast("int",1));.
table.addCell(cell);
table.writeSelectedRows(0,-1,45,525,over);
stamp.close();
I don't know what seems the problem, I use the told method.
It is a problem with the wmf file, because it works with other the image types (gif and png). You could use one of the other image types instead. Apparently it was corrected in a later version, but that will not help you unless you are using the JavaLoader.cfc.
http://www.mail-archive.com/itext-questions@lists.sourceforge.net/msg28534.html
What is the error message?
The following information is meant for the website developer for debugging purposes. | ||||||||||
Error Occurred While Processing Request | ||||||||||
Can you post a small runnable example that generates this error? I do not have any problem with 8,0,1,195765.
Thank you !
