Hi Kari
Can you please clarify that a tad?
Is the Excel file located in a place where someone else will be updating
it and you want no further interaction with it. Only for the user to see
the updates?
I ask because there are basically two ways to approach this. The method
I offer depends on how you foresee things operating.
Cheers... Rick
Hi Rick
You have understood me right but I will try to clarify a bit. The Help application we are planning includes hyperlinks to External files (e.g. MS Excel). The contents of these files is updated by other people every now and then but the name and the path on the server remains the same. We would like WebHelp to read the updated file without regenerating, replacing and owerwriting it in a project subfolder (!SSL!/WepHelp) every time when the update has been made. This works in WinHelp (CHM files), which I have made with Robohelp earlier. I hope I was able to describe our problem.
Thanks and best regards,
Kari
Hi Kari,
It should work just fine, I use links to external files in my project and when they are updated, since the link goes to the remote location, the updated file is atomatically loaded.
When you create the link to the file, make sure you don't select the "copy this file into the project" option. (see my screenshot, select No)
Thanks, Mark
Hi Kari
One way to achieve this is by using what I refer to as a "DocFetch" topic. Please allow me to explain.
Basically what you do is create a "redirect" topic. This is a topic with code inside the HTML that redirects to a different location. What I did was to create a topic with nothing more than an animated image and a message that the user should "Please wait while your document is being loaded".
The benefit of this is twofold.
Hopefully this helps... Rick
Hi Rick!
Thanks a lot for your advice...it works!
-Kari-
