Welcome to our community, Anthony
Basically you are doing everything right. I'm a bit unclear
on what you were expecting to see. Perhaps it will help you if I
explain how the Question Pools and Random Questions work.
You define a pool of questions using the Question Pools
Manager. You advise you have done that. So far so good.
You then insert a Random Question Slide. When you insert one
of these, you point the slide at a Question Pool. You advise that
you have done that too.
I'm guessing here that perhaps you expected that by inserting
a single Random Question Slide you would end up presenting all 13
questions from the pool. Just in random order?
If so, that's not how it was designed to work. What happens
is that a single random question from the pool is presented. If you
desire to see all 13 of your questions, but in random order, you
need to insert 13 Random Question Slides and point them at your
Question Pool.
You may wonder at this point if you do this, will it would be
possible to see perhaps question 2 multiple times. And the answer
to that is no. Once a question has been presented, it is removed
from consideration in the pool. So after the first one is
presented, Captivate randomizes from what remains in the pool.
Hopefully that helps better explain it.
Cheers... Rick
