Object Instantiation Exception. Creating Java Object
Participant ,
Apr 07, 2009 Apr 07, 2009
I am trying to implement CyberSource Simple Order API and I am getting an error on CFobject
An exception occurred when  instantiating a Java object. The class must not be an interface or an abstract  class. Error: com/cybersource/ws/client/ClientException.
So far I've placed the .jar file into :\ColdFusion8\wwwroot\WEB-INF\lib directory and on my cfpage I got:
<cfobject action="create" type="Java" class="CyberSource" name="auth">
Does anyone have any experience with CyberSource or the source of the error code?
Thanks in advance!
Advanced techniques
28.7K
Valorous Hero ,
You need to include the class's package (ie path), as well as the class name.  For example:
<cfset obj = createObject("java", "com.cybersource.ws.client.SomeClass")....>  .. instead of
<cfset obj = createObject("java", "SomeClass")....>
I do not use Cybersource, but you might review these references. The example on page 17 may be outdated, but it looks like a good starting point.
http://www.cfug-md.org/meetings/Montreal_CreditCardPayments.ppt
http://apps.cybersource.com/library/documentation/dev_guides/Simple_Order_API_Client_Java/html/intro.htm#intro_14664_14665
Participant ,
Apr 08, 2009 Apr 08, 2009
Thanks for the reply, I figured out why I am getting the error.  I needed to include the rest of the Java classes that come with the package.  As soon as I did that it worked, somewhat.
Now I am getting another error:
500
ROOT CAUSE:
java.lang.NoClassDefFoundError: Could not initialize class com.cybersource.ws.client.Signature
It looks like when it tries to run a function inside the java class:
<cfset myReply = auth.runTransaction(propsFile,myRequest)/>
Valorous Hero ,
Yes, the entire jar (and any supporting jars) must be placed in the CF class path. The error message indicates it needs a class named com.cybersource.ws.client.Signature but cannot find it.  Does that class exist in your cybersource jar(s)? Did you place all of the needed jars in the CF classpath?
Jul 22, 2009 Jul 22, 2009
Did you guys manage to figure out the solution to that last error - the 500 ROOT CAUSE:
java.lang.NoClassDefFoundError ??
I had the same problems going forward and now have landed at this one as well. Any ideas?
Thanks-
Valorous Hero ,
I do not know if the OP ever resolved their issue.
NoClassDefFoundError is a generic error that basically means the class cannot be loaded.  The underlying reasons can vary.  Are you using the same jar listed above and how/where did you install the jar?
I had the sysadmin put the jar files directly into the coldfusionRoot/WEB-INF/lib directory. I had initially received the same original error the OP had, and it went away after copying all 4 of the required JAR files into the coldfusionRoot/WEB-INF/lib directory. Now, I get this 500 error.
Valorous Hero ,
What does the detail the error message say? Do they have a publicly available API?
The API files and documentation can be found in the matrix here:
http://www.cybersource.com/support_center/implementation/downloads/simple_order/matrix.htmlUnfortunately,
there is very scant information pertaining to plugging Coldfusion into the
Java version, its kind of tagged onto it.
Full error detail:
500
ROOT CAUSE:
at com.cybersource.ws.client.Client.soapWrapAndSign(Client.java:200)
at com.cybersource.ws.client.Client.runTransaction(Client.java:103)
at com.cybersource.ws.client.Client.runTransaction(Client.java:53)
at CyberSource.runTransaction(CyberSource.java:32)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at coldfusion.runtime.java.JavaProxy.invoke(JavaProxy.java:87)
at coldfusion.runtime.CfJspPage._invoke(CfJspPage.java:2272)
at cfcheckout22ecfm2002022632.runPage(/usr/local/apache2/htdocs/sfs/cybersource_api_test/checkout2.cfm:42)
at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:196)
at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:370)
at coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:65)
at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:279)
at coldfusion.filter.MonitoringFilter.invoke(MonitoringFilter.java:40)
at coldfusion.filter.PathFilter.invoke(PathFilter.java:86)
at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:70)
at coldfusion.filter.BrowserDebugFilter.invoke(BrowserDebugFilter.java:74)
at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:28)
at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38)
at coldfusion.filter.NoCacheFilter.invoke(NoCacheFilter.java:46)
at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38)
at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
at coldfusion.filter.RequestThrottleFilter.invoke(RequestThrottleFilter.java:126)
at coldfusion.CfmServlet.service(CfmServlet.java:198)
at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:89)
at jrun.servlet.FilterChain.doFilter(FilterChain.java:86)
at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:42)
at coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46)
at jrun.servlet.FilterChain.doFilter(FilterChain.java:94)
at jrun.servlet.FilterChain.service(FilterChain.java:101)
at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:106)
at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)
at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:286)
at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:543)
at jrun.servlet.jrpp.JRunProxyService.invokeRunnable(JRunProxyService.java:203)
at jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPool.java:320)
at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:428)
at jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable(ThreadPool.java:266)
at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
javax.servlet.ServletException: ROOT CAUSE:
at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:70)
Valorous Hero ,
It should be easy to convert the java version to CF.  Did you properly install the client. It seems like that is required first:
See: Installing and Testing the Client
http://apps.cybersource.com/library/documentation/sbc/api_guide/html/
Yes, my sysadmin installed the java API client on the server, and did some
test API transactions to the test cybersource server, which were successful.
The Java API client has some script files to run the pure Java version of
the API to send a transaction to Cybersource. I was able to log into the
Cybersource business center to confirm that the transactions were received.
The next step was to integrate Coldfusion into the process. The coldfusion
option piggybacks on the Java Client, and generates a Java object inside
coldfusion from the Java API client on the server. The sample Coldfusion
templates which were provided with the API download were put on the server,
and then they were edited to point to the API properties file. After an
initial failure, I realized those JAR files needed to be made available in
the class path and we copied them over.
After that, the initial class not found exceptions ceased, but instead now
we get this 500 error.
Valorous Hero ,
What are the other jars?  Perhaps one of them conflicts with a version already in use by CF. It comes already bundled with a bunch of jars, sometimes used by other applications.
The following is an excerpt from some of the (limited) actual instructions
for the Coldfusion portion of the Java/Coldfusion Simple Order API for
Cybersource.
The ColdFusion directory contains the additional jar file, cybs-cfm.jar,
that
you need to include in your CLASSPATH in order to integrate the Simple Order
API for Java into your ColdFusion applications. It also contains samples
for
both Name-Value Pair and XML clients. They have been tested with ColdFusion
MX 7.
To add the CyberSource jar files to the CLASSPATH used by ColdFusion, edit
the
file <coldfusion_dir>/runtime/bin/jvm.config and append the full path of the
following jar files to the value of "java.class.path":
cybsclients14.jar OR cybsclients15.jar (depending on the JVM version)
cybssecurity.jar
xercesImpl.jar
cybs-cfm.jar
For example, on Windows, if you installed the Simple Order API in
"c:\Program Files\CyberSource Corporation\simapi-java-5.0.2", you would add
the
following paths:
c:/Program Files/CyberSource
Corporation/simapi-java-5.0.2/lib/cybsclients14.jar;c:/Program
Files/CyberSource
Corporation/simapi-java-5.0.2/lib/cybssecurity.jar;c:/Program
Files/CyberSource
Corporation/simapi-java-5.0.2/lib/xercesImpl.jar;c:/Program
Files/CyberSource Corporation/simapi-java-5.0.2/coldfusion/lib/cybs-cfm.jar
You will need to restart the ColdFusion application server in order for your
change to take effect. On Windows, you will need to restart the "ColdFusion
MX 7 Application Server" service.
Valorous Hero ,
ColdFusion 7 and 8 already include a version of xercesImpl.jar. That might be causing a conflict.
1. Try removing that jar's path from the CLASSPATH + /runtime/bin/jvm.config file
Update:  ie Remove this path
c:/Program Files/CyberSource Corporation/simapi-java-5.0.2/lib/xercesImpl.jar;
AND
2. Remove the physical jar file from WEB-INF\lib
Then restart CF to apply the changes.
There is a much older conversation here involved the xerces JAr it seems:
http://www.justskins.com/forums/coldfusion-java-guru-install-cybersource-java-api-79208-2.html
Anyway - so back to your suggestions, from where should Coldfusion end up
references the xerces JAR? If I remove it from the Classpath, and the
jvm.config file, and remove the physical jar file from Web-INF/lib, where
will it find it? Won't it be nowhere then?
(thank you for your help btw - it is much appreciated)
Oh, are suggesting to have the API Client reference the original xerces JAR file that Coldfusion had already? And to not use the one that came with the files in the API Client download?
Also - we didn't make any changes to the class path at all, all we did was move the JAR files that came with the API download, into the coldfusionroot/WEB-INF/lib directory.
Valorous Hero ,
Yes, exactly.   Sometimes having two versions of a jar in the classpath causes the jvm to get confused and fall down.  By removing the extra version, hopefully it will eliminate the error. If indeed that is the problem here.
That is okay about the classpath.  If you did not change the jvm.config file, removing the jar from WEB-INF/lib should do the trick.  (The reason is WEB-INF/lib is already in CF's classpath. So it knows it should load any jars it finds in that folder).
Valorous Hero ,
http://www.justskins.com/forums/coldfusion-java-guru-install-cybersource-java-ap i-79208-2.htmlis
I read the older thread. One thing that is different about MX6 is that it did not ship with a version of xercesImpl.jar (As far as I know).  Both MX7 and CF8 appear to include Xerces-J 2.6.2 .  I took a quick look and that seems be the same version included with cybersource.  So hopefully it should be compatible.
removed the xercesImpl.jar from the path /opt/coldfusion8/wwwroot/WEB-INF/lib/ and restarted coldfusion.
Now getting the errors:
500
ROOT CAUSE:
java.lang.NoClassDefFoundError: org/apache/xerces/dom/DocumentImpl
Valorous Hero ,
Weird. You are sure you rebooted?
1. What version of CF are you using?
2. Are you using the code CF sample from cybersource (ie checkout2.cfm)? If so, on which line does the error occur ?
From that older thread - from the support person -
"The xerces version that comes with the CDK is the important portion here, as
it is required in order to sign the soap message with the RSA libraries that
are part of the client. If any other xerces version is used besides the one
included in the CDK, then it will fail with the java.lang.null that is commonly
seen."
would that be synonamous with the error I was just now getting after removing that xerces JAR?
version is CF 8, my sysadmin knew it had to be rebooted
I"m using the code samples provided with the API - it appears that it is failing at the exact same spot the OP indicated above. Inbetween dumping the Request and Response.
<cfdump label="Request" var="#myRequest#"/><br>
  <cfdump label="Response" var="#myReply#"/>
Valorous Hero ,
I do not think so. Not unless you are seeing a null exception somewhere further down the chain. That comment refers to a NullPointerException (ie something is totally undefined) and the error you are getting is NoClassDefFoundError. The latter usually means there was a problem loading something, not necessarily that it could not be found.  But the causes vary.
But in any case, that version _should_ be okay.  According to the MANIFEST files the CF version seems the same as the cybersource version.   Did you check the logs? Maybe they contain a more detailed error.
Well, I mean I got the full error displayed on the page:
500
ROOT CAUSE:
     at com.cybersource.security.asymmetric.signature.WsSecuritySign.signDocument(WsSecuritySign.java:46)
     at com.cybersource.ws.client.Signature.sign(Signature.java:65)
Valorous Hero ,
It almost seems like you were better off with the first error.  Where there any "Caused by:" details for the first error or just:
Documentation
