I am wondering how to make a mute and unmute button is actionscript 3.0. I did it before in actionscript 2.0 but not in 3.0.
Here is my actionscript 2.0 code.
var sound = 1;
var slashMC = _root.attachMovie("slash","slash01",99);
slash01._visible = false;
slashMC._y = btn._y;
slashMC._x = btn._x;
var s:Sound = new Sound();
s.attachSound("Gravy");
s.start(1,999);
btn.onPress = function(){
if(sound==1){
s.stop();
slash01._visible = true;
sound = 0;
else if(sound==0){
sound = 1;
s.start(1,999);
You could try something like this:
private function changeSound(event:MouseEvent)
var st:SoundTransform = new SoundTransform();
if(soundOn)
st.volume = 0;
SoundMixer.soundTransform = st;
soundIsOn = false;
else
st.volume = 1;
soundIsOn = true;
small correction to your code:
if(soundIsOn)
st.volume = 0;
soundIsOn = false;
else
st.volume = 1;
soundIsOn = true;
Thanks for the catch.
Where do I put the code. Do I put it in frame 1.
You can put it in frame one, on a seperate layer though. Also, if you're adding this to the timeline, take off the private part of the funciton.
I put the code in frame one. How do attach the sound because I dont hear the sound.
My code now looks like this. I removed private from private function...
var soundIsOn = true
if(soundIsOn)
st.volume = 0;
soundIsOn = false;
else
st.volume = 1;
soundIsOn = true;
yeh that should be fine.
I don't here the sound.
Dont I have to attach the sound somehow.
thanks
Here is another version.
var soundIsOn=true;
btn.addEventListener(MouseEvent.CLICK, changesound);
function changeSound(event:MouseEvent) {
if (soundIsOn) {
st.volume=0;
SoundMixer.soundTransform=st;
soundIsOn=false;
} else {
st.volume=1;
soundIsOn=true;
the code provided before is ONLY for the mute functionality you need to create your soundobject as well.
Try this:
import flash.display.MovieClip;
import flash.events.*;
import flash.media.*;
import flash.net.URLRequest;
var isPlaying:Boolean = false;
var snd:Sound = new Sound();
var channel:SoundChannel = new SoundChannel();
var pos:Number = 0;
var soundVolume:Number = 1;
snd.load(new URLRequest("something.mp3"));
btn_Stop.addEventListener(MouseEvent.CLICK, stopMusic);
btn_Stop.buttonMode = true;
btn_Play.addEventListener(MouseEvent.CLICK, playMusic);
btn_Play.buttonMode = true;
function stopMusic(evt:Event):void
channel.stop();
pos = 0;
isPlaying = false;
function playMusic(evt:Event):void
if(!isPlaying)
channel = snd.play(pos);
btn_Play.visible = false;
btn_Pause.visible = true;
isPlaying = true;
Thanks for the code. I will look it over and post what happens. Sorry about the delay.
