I created a form in LiveCycle on top of an existing PDF. The form has 2 text fields (a company name) and an image (a company logo), and all are dynamically populated depending on who requested the form. I am using CF 8 to read the database and populate the fields. See tags below.
1. I have tried a zillion different ways to generate a line feed in one of the text fields but to no avail. In all cases, the characters actually appear in the output text. Supposedly the LiveCycle doc says I can use udf escape sequences like "\u000d\u000a" but those do not work Other attempts included '\x0d\x0a' " \r" "<br>" \line but to no avail.
Does anyone know what character sequence to embed in a text field to cause a line feed in the output PDF?
2. I cannot find any documentation on how to specify the value for an imagefield on the PDF form. I am trying to place a company logo but nothing comes out on the pdf. Apparently I need something other than value="logofilename.jpg" but I can't find any doc on what to use.
Here is my code - very simple:
<cfpdfform source="#sourcePDFpath#" action="populate">
<cfpdfsubform name="topmostsubform">
<cfpdfformparam name="txtAssocName" value="#Trim(assocName)#"> <!--- this displays OK --->
<cfpdfformparam name="txtAssocAddress" value="#Trim(assocAddrFields)#" > <!--- line feeds are not working between city and state --->
<cfpdfformparam name="logo" value="1.jpg" > <!--- image does not display --->
</cfpdfsubform>
</cfpdfform>
Thank you, in advance, for your help!
I have found the solution to question #1 below - this seems to work: '#chr(10)##chr(13)#'
Now if I can only find out how/what to use to embed an image, I'll be in good shape.
Not sure if there is a way to pass a graphic into a PDF like that, but I've done it lots of times by positioning the graphic onto a PDF file using the iText java library (ships with CF). Might want to head over to http://www.lowagie.com/iText/ to check it out.
