secure-amf problem
Avatar
Level 1
i am able to connect through unsecure amf but i get the
following error when trying to connect through secure amf.
[RPC Fault faultString="Send failed"
faultCode="Client.Error.MessageSend"
faultDetail="Channel.Security.Error error Error #2048: Security
sandbox violation:
http://192.168.0.53:8080/i4sale/views/i4sale.swf
cannot load data from
https://192.168.0.53:8443/i4sale/messagebroker/amfsecure."]
at mx.rpc::AbstractInvoker/
http://www.adobe.com/2006/flex/mx/internal::faultHandler()
at mx.rpc::Responder/fault()
at mx.rpc::AsyncRequest/fault()
at mx.messaging::ChannelSet/::faultPendingSends()
at mx.messaging::ChannelSet/channelFaultHandler()
at
flash.events::EventDispatcher/flash.events:EventDispatcher::dispatchEventFunction()
at flash.events::EventDispatcher/dispatchEvent()
at
mx.messaging.channels::NetConnectionChannel/::defaultErrorHandler()
at
mx.messaging.channels::NetConnectionChannel/::securityErrorHandler()
My services config looks as follows:
<?xml version="1.0" encoding="UTF-8"?>
<services-config>
<services>
<service-include file-path="remoting-config.xml" />
<service-include file-path="proxy-config.xml" />
<service-include file-path="messaging-config.xml" />
<service-include file-path="data-management-config.xml"
</services>
<security>
<login-command
class="flex.messaging.security.JRunLoginCommand" server="JRun"/>
<!-- Uncomment the correct app server
<login-command
class="flex.messaging.security.TomcatLoginCommand"
server="Tomcat"/>
<login-command
class="flex.messaging.security.WeblogicLoginCommand"
server="Weblogic"/>
<login-command
class="flex.messaging.security.WebSphereLoginCommand"
server="WebSphere"/>
<security-constraint id="basic-read-access">
<auth-method>Basic</auth-method>
<roles>
<role>guests</role>
<role>accountants</role>
<role>employees</role>
<role>managers</role>
</roles>
</security-constraint>
</security>
<channels>
<channel-definition id="my-amf"
class="mx.messaging.channels.AMFChannel">
<endpoint uri="
http://{server.name}:{server.port}/{context.root}/messagebroker/amf"
class="flex.messaging.endpoints.AMFEndpoint"/>
<properties>
<polling-enabled>false</polling-enabled>
</properties>
</channel-definition>
<channel-definition id="my-secure-amf"
class="mx.messaging.channels.SecureAMFChannel">
<endpoint
uri="https://{server.name}:8443/{context.root}/messagebroker/amfsecure"
class="flex.messaging.endpoints.SecureAMFEndpoint"/>
<channel-definition id="my-polling-amf"
<endpoint uri="
http://{server.name}:{server.port}/{context.root}/messagebroker/amfpolling"
<properties>
<polling-enabled>true</polling-enabled>
<polling-interval-seconds>8</polling-interval-seconds>
</properties>
<channel-definition id="my-rtmp"
class="mx.messaging.channels.RTMPChannel">
<endpoint uri="rtmp://{server.name}:2038"
class="flex.messaging.endpoints.RTMPEndpoint"/>
<properties>
<idle-timeout-minutes>20</idle-timeout-minutes>
<client-to-server-maxbps>100K</client-to-server-maxbps>
<server-to-client-maxbps>100K</server-to-client-maxbps>
<!-- for deployment on WebSphere, must be mapped to a
WorkManager available in the web application's jndi context.
<websphere-workmanager-jndi-name>java:comp/env/wm/MessagingWorkManager</websphere-workmanager-jndi-name>
</properties>
<channel-definition id="my-http"
class="mx.messaging.channels.HTTPChannel">
<endpoint uri="
http://{server.name}:{server.port}/{context.root}/messagebroker/http"
class="flex.messaging.endpoints.HTTPEndpoint"/>
<channel-definition id="my-secure-http"
class="mx.messaging.channels.SecureHTTPChannel">
<endpoint
uri="https://{server.name}:8443/{context.root}/messagebroker/httpsecure"
class="flex.messaging.endpoints.SecureHTTPEndpoint"/>
</channels>
<logging>
<target class="flex.messaging.log.ConsoleTarget"
level="Error">
<properties>
<prefix>[Flex] </prefix>
<includeDate>false</includeDate>
<includeTime>false</includeTime>
<includeLevel>false</includeLevel>
<includeCategory>false</includeCategory>
</properties>
<filters>
<pattern>Endpoint.*</pattern>
<pattern>Service.*</pattern>
<pattern>Configuration</pattern>
</filters>
</target>
</logging>
<system>
<redeploy>
<enabled>true</enabled>
<watch-interval>20</watch-interval>
<watch-file>{context.root}/WEB-INF/flex/services-config.xml</watch-file>
<watch-file>{context.root}/WEB-INF/flex/proxy-config.xml</watch-file>
<watch-file>{context.root}/WEB-INF/flex/remoting-config.xml</watch-file>
<watch-file>{context.root}/WEB-INF/flex/messaging-config.xml</watch-file>
<watch-file>{context.root}/WEB-INF/flex/data-management-config.xml</watch-file>
<touch-file>{context.root}/WEB-INF/web.xml</touch-file>
</redeploy>
</system>
<factories>
<factory id="springFactory"
class="com.cme.factories.SpringFactory"/>
</factories>
</services-config>
please help, thank you.
