1. Re: Trouble with color profiles?
Buko. Apr 13, 2009 1:34 PM (in response to thehearth)your monitor profile should never be your working space. choose sRGB or Adobe RGB or whaterver but NEVER EVER use your monitor profile. Or your proof colors for that matter.
Nobody but you has your monitor profile.
2. Re: Trouble with color profiles?
thehearth Apr 13, 2009 2:45 PM (in response to Buko.)The work space actually isn't set to Monitor Color. It's set to sRGB. I reset everything to Photoshop's defaults and now proof colors and display colors all match, but saved jpg files are actually much worse. If I use the save for web dialogue and turn off "embed color profile" and "convert to sRGB" then it comes close, but it's still not right. If I leave them on, the color difference is crazy. I attached another example.
Picture 1.png 1.1 MB
3. Re: Trouble with color profiles?
David Remington Apr 13, 2009 5:26 PM (in response to thehearth)Might not be PS. Did you hit one of the Universal Access keyboard short cuts? Check in the Keyboard shortcut pane of the Keyboard & Mouse control panel in System Preferences.
4. Re: Trouble with color profiles?
Lundberg02 Apr 13, 2009 5:31 PM (in response to David Remington)Ramon tells me that you should use the camera icon in your reply toolbar to load images. Attachments a re scanned for virii and take forever to load.
6. Re: Trouble with color profiles?
Ramón G Castañeda Apr 13, 2009 6:12 PM (in response to thehearth)This has been discussed ad nauseam here, and there are many existing threads on the subject. This type of thread can get very long in no time. I suggest you take a look at them.
In a nutshell, you need to calibrate and profile your monitor accurately, select a working color space, honor that tag (color space) in all files you open, and tag all your files with the color profile in which they were created. Then look at the image in a color managed application.
If you choose not to embed the color profile in a JPEG, meaning you end up with an untagged JPEG file, be prepared to see color differences between the appearance of the image in some applications, most especially if you have a wide-gamut monitor. For instance, Photoshop and Firefox 3.0.8 (the latter with color management enabled, which is not by default) will correctly assume sRGB for all untagged images. On the other hand, all Apple applications, from the Finder through Preview, Safari, iPhoto and Aperture, just throw monitor profile at all untagged images. That will produce exactly the effect you show.
Similarly, if you leave an image created in, say ProPhoto RGB, untagged, it will look like it's on fire in Photoshop and Bridge, as well as in the Finder, etc.
To beging learning about color management, start here: http://www.gballard.net/psd/cmstheory.html
7. Re: Trouble with color profiles?
David Remington Apr 13, 2009 6:31 PM (in response to Ramón G Castañeda)Ramon,
I think you called it. But Your Prophoto example is reversed. A untagged Prophoto edited image will look dull in a monitor space. On the other hand, untagged images from smaller gamut spaces will look look they are on fire in PS if your working space is PP.
--David
8. Re: Trouble with color profiles?
thehearth Apr 13, 2009 7:16 PM (in response to David Remington)Thank you guys for the help. I tried to search, but I wasn't sure exactly how to search. I have a calibrator which has been begging for use. I suppose that this is the excuse I need--crippling color variations.
Thanks again for the help!
9. Re: Trouble with color profiles?
Ramón G Castañeda Apr 13, 2009 7:28 PM (in response to David Remington)David Remington wrote:
Ramon,
You are correct, of course. Thanks for catching it.
10. Re: Trouble with color profiles?
Ramón G Castañeda Apr 13, 2009 7:33 PM (in response to thehearth)thehearth wrote:
What?! What do you mean by "excuse"?
Calibrate and profile your monitor regularly and often. I validate the calibration of my monitors virtually on a daily basis.
Would you wait for an "excuse" to brush your teeth? Yuk!
11. Re: Trouble with color profiles?
thehearth Apr 13, 2009 7:36 PM (in response to Ramón G Castañeda)Maybe I've just gotten lucky. But to be honest, I've never seen a discrepency from computer to computer to browser to browser, even in print, my colors have always been pretty much exactly as I wanted and expected them to be--without ever calibrating. I dunno. Maybe I'm actually colorblind, but no one's ever complained either.
12. Re: Trouble with color profiles?
Ramón G Castañeda Apr 13, 2009 8:12 PM (in response to thehearth)thehearth wrote:
Possibly. Few people complain to the offender about his/her bad breath problem either. Or you're just not that fussy about critical color, or you're just seeing the lowest common denominator across mediocre monitors, or…
The possibilities are many.
