Hello all,
I found that any CSS format for expanding text hotspots is
overridden by the link format. If I define hotspots red then this
works, but if I additionally define links blue then both link and
hotspots appear blue in the output. The WYSIWYG-Editor does not
display correctly.
Is this a fact or can I work around and use two different
formattings?
Now I found the solution: Simply alter the order of the
definitions in the CSS stylesheet and it works! When I place the
hotspot class definition at the end then it is not overridden by
the link format anymore.
So this is actually sort of a bug of the standard RoboHelp
output.
