Hello Tony,
Whilst Captivate does recognize different mouse clicks (in so
much as the application will capture a right-click menu) you cannot
specify what type of mouse effect the application will use when you
capture.
What you can do is change the mouse click effect post
capture. To do this and with a just captured project open carry out
these steps:
1. Select the slide that has a mouse pointer where you would
like need to show a right-click action.
2. Choose Slide > Mouse > Properties...
3. In the Mouse Properties dialog make sure that the option
"show mouse click" is selected and then show either the color or
the custom effect you would like to use to represent the
right-click operation.
Naturally, at the very start of your movie/project you would
need to inform the learner that each time they see the one of the
effect you want them to right-click. You could also include some
audio as well which would be important if you need to adhere to
accessibility standards.
In regard to your second question, in most cases you will
find that you get the best result if you adjust the mouse timing
using the Timeline.
That said if you own a copy of Adobe Captivate 2 you can
change the mouse Display and Appear After settings globally via the
Mouse Properties dialog. Personally, for mouse movement I would not
recommend this. Anyway here are the steps to carry that out.
1. Select any slide that has a mouse pointer present.
3. Click the Timing tab
4. Change the Display time and Appear After values
5. Click the Settings button
6. Choose the appropriate options from both Which properties
and which slide categories
7. Click OK.
Note : You can also show the Mouse properties dialog by left
clicking on mouse icon on any of the slides in the Filmstrip
Mark
