Sorry for the delayed response. More than anything, I'd like to know if WebHelp compatibility with Firefox has been improved. I understand that new topics created in RH8 are XHTML. I assume opening/upgrading a project from a previous version in RH 8 does not convert/clean up the code? Does the new XHTML code allow for improved WebHelp output and/or has the WebHelp engine been improved to produce cleaner HTML that renders in other browsers as well as it does in IE? For example, when removing the underline from a hyperlink, RH wraps the hyperlink in a <span> tag, with a decoration of none. In IE, the hyperlink is not underlined, but in Firefox the underline still appears. We have to manually delete the <span> tags in the HTML view.
Thanks, AK
MyCows wrote:
1] ...I assume opening/upgrading a project from a previous version in RH 8 does not convert/clean up the code?
2] ... Does the new XHTML code allow for improved WebHelp output and/or has the WebHelp engine been improved to produce cleaner HTML that renders in other browsers as well as it does in IE?
3] ...For example, when removing the underline from a hyperlink, RH wraps the hyperlink in a <span> tag, with a decoration of none. In IE, the hyperlink is not underlined, but in Firefox the underline still appears. We have to manually delete the <span> tags in the HTML view.
Thanks, AK
1] You assume wrong. It has to rewrite the code as otherwise old and new topics could not be handled in the editor.
2] The output code is also changed to make it work with different browsers. Only you can tell whether it is exactly what you want as your input is a factor.
3] I have not seen that problem. The trial version is fully functional and free. Best not to put it on your production machine or work with the original of your projects.
AK,
For #3 specifically, it sounds like you're manually turning off underlining by highlighting a link and going to Format > Font. Is that right, or are you using styles? Getting rid of link underlining should work better if you specify no underlining in the CSS by going to Format > Styles and changing the styles of the hyperlink states.
Great stuff. Thanks for the suggestion Ben!
I'll give the trial and whirl and see if it works the way I'm hoping.
Thanks everyone!
AK
