I'm generating webhelp from Robohelp 8, and I can't get my styles to apply to the content. I applied my style sheet to my topics, so not sure what the problem is. I don't have a Master Page - do I have to have one for my content to be properly styled in the browser?
If anyone has any suggestions, I'm willing to try them. Thanks!
Perhaps see if this topic helps. It's for CHM output, but might apply for webhelp also.
No, all the links are of the text/css type, so still not sure why it's not displaying. I'm tearing my hair out over this, because everything else works!
Are your topics created by import from Word? Have you looked at the HTML for embedded style sheets and inline styling?
Does this occur in Preview or just in the browser?
If it is just the browser, when you generate have you maybe set a different CSS to apply?
No, did not import from Word; used Dreamweaver to create the html (which I've double-checked for the appropriate <link rel="stylesheet" href="default.css" type="text/css" /> code).
Occurs in the browser. Looks fine in the Robohelp Starter pod. I have that sample project provided with Robohelp, and I've checked it; styling appears as it should.
Just don't know what I'm doing/not doing...
Thanks for the suggestions!
Import one of your topics into a new project and verify that it has the same problem. If it has, then zip it up and send it via my site.
I have the same issue. Emailed you as well. I tried changing to Master Page option--no luck.
Followed the link posted in this thread and tried some things but cannot seem to get this to work.
See if you can recreate this in a small project and post here its size when zipped.
I am looking at the forum post. Same code is in individual HTML files but not in .css. I am going to see what I can do....
Finally fixed. I compared code in a working style sheet to the one that was not working.
The one that was not working had an extra bracket thrown into the DIV.divcontent header. I deleted & all seems to be OK.
great! a relief, to solve the issue!
-- e.
I figured out that it was a character set definition in the css. don't ask me why, but Dreamweaver stuck it in there at some point. The code I removed was: @charset utf-8 { };
-- Eliz.
Hi, all. I figured out the following line of code had somehow been inserted into my css and was causing the problem: @charset utf-8 {
}; Since I didn't deliberately specifiy the utf-8 character set, either Dreamweaver or Robohelp did something peculiar. Not sure what happened.
Thanks for posting the solution.
