import com.adobe.livecycle.output.client.*;
import java.util.*;
import java.io.File;
import java.io.FileInputStream;
import com.adobe.idp.Document;
import com.adobe.idp.dsc.clientsdk.ServiceClientFactory;
public class CreatePDFDocument {
public static void main(String[] args) {
try{
//Set LiveCycle ES service connection properties
Properties ConnectionProps = new Properties();
ConnectionProps.setProperty("DSC_DEFAULT_EJB_ENDPOINT", "jnp://localhost:1099");
ConnectionProps.setProperty("DSC_TRANSPORT_PROTOCOL","EJB");
ConnectionProps.setProperty("DSC_SERVER_TYPE", "JBoss");
ConnectionProps.setProperty("DSC_CREDENTIAL_USERNAME", "administrator");
ConnectionProps.setProperty("DSC_CREDENTIAL_PASSWORD", "password");
//Create a ServiceClientFactory object
ServiceClientFactory myFactory = ServiceClientFactory.createInstance(ConnectionProps);
//Create a SignatureServiceClient object
OutputClient outClient = new OutputClient(myFactory);
//Reference form data
FileInputStream fileInputStream = new FileInputStream("C:\\Adobe\\Loan_data.xml");
Document inXMData = new Document (fileInputStream);
//Set PDF run-time options
PDFOutputOptionsSpec outputOptions = new PDFOutputOptionsSpec();
outputOptions.setFileURI("C:\\Adobe\\Loan.pdf");
//Set rendering run-time options
RenderOptionsSpec pdfOptions = new RenderOptionsSpec();
pdfOptions.setLinearizedPDF(true);
//Create a PDF document
OutputResult outputDocument = outClient.generatePDFOutput(
TransformationFormat.PDF,
"Loan.xdp",
"C:\\Adobe",
outputOptions,
pdfOptions,
inXMData
//Retrieve the results of the operation
Document metaData = outputDocument.getStatusDoc();
File myFile = new File("C:\\Adobe\\Output.xml");
metaData.copyToFile(myFile);
catch (Exception ee)
ee.printStackTrace();
While Trying to run this sample i am getting the following message "Unable to create / open file C:\Adobe\Loan.pdf" in Output.xml file
outClient.generatePDFOutput is not called...
Please suggest me i am new Adobe Lifecycle.
Total Likes
May be a Loan.pdf exists and is open!
Also, try using the SOAP endpoint. The EJB endpoint is usually problematic. See if it helps.
Total Likes
