12 Replies Latest reply: Apr 18, 2009 1:32 AM by Phos±four dots RSS
    img tag attributes test
    Phos±four dots Community Member
      Dang! I either have to learn modernized code for putting "vspace" next to images in the HTML message composition area, or these forums don't respect the code I'm writing.  Funny thing—the "vspace" and "hspace" attributes seem to appear in the "full editor" but not in the message body once it's posted.
      Lorem ipsum paulo dicunt oporteat vim ex, qui graece viderer tamquam ex. Qui at tantas fabellas recteque! Ferri nihil tantas mea et. Nonumy accusam appareat at nec, mollis eruditi placerat ut vel, utroque fastidii intellegam mel at. Quo nominavi facilisi conceptam an. Ad sit accumsan contentiones, minim veritus comprehensam no pri?
      Vis ne omnis euismod, usu at movet docendi, duo ea ubique senserit omittantur. Sanctus gloriatur ullamcorper vis an, id audire phaedrum rationibus per, eum ad diam atqui velit? Quo at delenit nominavi menandri, eu essent aliquam voluptaria vel, ea pri noluisse petentium contentiones. Dico erat ridens mel ne, dicta alienum consectetuer id pri! Ut democritum delicatissimi conclusionemque eam, usu id ubique quaeque inciderint. An affert labores petentium vix, blandit tincidunt ius an, has erat solum salutandi ei.
        • 1. Re: img tag attributes test
          Ildhund Community Member
          in *** simul inimicus, ei choro eruditi dissentiunt sed. Eu *** corrumpit
          neglegentur
          Dying to know which rude Latin words got excised by Nanny.
          Noel
          [PS the link at the beginning got mangled - it wanted some space before
          'Lorem'.]
          • 2. Re: img tag attributes test
            neglegentur
            Noel
            'Lorem'.]
            The *** is stuck in there in place of "c u m" as in magna c u m laude.
            Stupid ƒucking overlords.
            • 3. Re: img tag attributes test
              And I sure would like to know what flavor of HTML or XML or whatever they're checking against in the HTML editor, because I haven't visited too many other places that are as strict as the input/parsing here.
              And if anyone is reading this who might know:
              What form of coding do I need to brush up on in order to get simple things like spacing around an image to work?
              • 4. Re: img tag attributes test
                Kath-H Community Member
                Lorem ipsum dolor sit amet, consectetuer adipiscing elit, sed diam nonummy nibh euismod tincidunt ut laoreet dolore magna aliquam erat volutpat. Ut wisi enim ad minim veniam, quis nostrud exerci tation ullamcorper suscipit lobortis nisl ut aliquip ex ea commodo consequat. Duis autem vel eum iriure dolor in hendrerit in vulputate velit esse molestie consequat, vel illum dolore eu feugiat nulla facilisis at vero eros et accumsan et iusto odio dignissim qui blandit praesent luptatum zzril delenit augue duis dolo
                • 5. Re: img tag attributes test
                  Like so?
                  • 6. Re: img tag attributes test
                    Inline css, since we've got no head to put the style sheet in.
                    <img style="margin-right:10px; float:left;" src=http://home.comcast.net/~phoz/bbs/cactuscd.jpg>Lorem ipsum etc
                    Note no quotes round the image source, like you usually have.
                    • 7. Re: img tag attributes test
                      That'll be at least 5 points please
                      hspace & vspace are so last century, man
                      • 8. Re: img tag attributes test
                        OK, veddy good then. I kinda figured it was something like that, but having gotten so used to the old style attributes, and having been prevented from using css in so many other places I wasn't sure exactly how to generate that space next to the image. As for the quotation marks...I've been on forums that require them for the image code to work, so I figured I'd use them here, since other parts seemed so strict.
                        And all that doesn't even mention that I generally hate code and suck at it anyway.
                        Time to add some new code snippets to my TextExpander utility.
                        Thanks, Kath.
                        • 9. Re: img tag attributes test
                          Most welcome.
                          • 10. Re: img tag attributes test
                            While you're paying attention here, there's something else you may want to be aware of, and get sorted out for yourself.
                            I was fixing up the Eyedropper FAQ ( http://forums.adobe.com/thread/370727?tstart=0 ) and really had to work to get that image to show up at full size. The forum kept wanting to resize and compress it, when I wanted to have it display at exactly the size it is. It did things to the image I'd never seen before; parts of the resized image looked like they were smeared, as if they were still-wet water color markers, while other parts of the image remained looking almost original.
                            Haven't posted enough images to get the whole process and the restrictions sussed, but I'll manage to eventually.
                            If I continue to bother with the forums, that is.
                            • 11. Re: img tag attributes test
                              ???? what image are you referring to please? That's an FAQ by Buko?
                              • 12. Re: img tag attributes test
                                Originally, that FAQ entry was posted by Buko.
                                It was inspired by a small spate of people asking the same question about the Eyedropper sampling color into the Background swatch instead of the default location of the Foreground swatch.
                                I answered the question in the main forum with the image.
                                ( http://home.comcast.net/~phoz/bbs/Eyedropper-Focus-Infographic.png )
                                Buko composed and posted the FAQ, but he didn't really answer the question as it was asked. He gave a workaround (tapping the 'X' key to switch FG <--->BG swatch colors). I begged for weeks, and finally got my image added to the FAQ. When the FAQ came across fromWebX to Jive, my image disappeared.
                                J.C. recently gave me FAQ access.
                                So I fixed it. Now it answers the question as asked.
