1. Re: Best way to capture from VHS source
John T Smith Apr 18, 2009 8:19 AM (in response to lanstrad)I guess that depends on what you call expensive... but just remember that every time you convert from one format to another, you MAY lose video quality, so doing only one conversion is best... both of these external converters require a Firewire card in the computer
Either of these external products produces DV AVI type 2 - which is best for editing in Premiere
ADS Pyro AV Link API-557-EFS (or higher than 557 ?)
http://www.videoguys.com/pyroAVlink.htmlOr http://desktop.thomsongrassvalley.com/products/ADVC300/index.php about $500
ttp://www.amazon.com/Canopus-ADVC300-Advanced-Digital-Converter/dp/B0006UMGHE
A message from the old forum...
"Matt with Grass Valley Canopus in their tech support department stated that the 110 will suffice for most hobbyist.
If a person has a lot of tapes that were played often the tape stretches and the magnetic coding diminishes. If your goal is to encode tapes in good shape buy the 110, if you will be encoding old tapes of poor quality buy the 300"
NOTE that I have not used either (I still use a Pinnacle Dv500 card) so these notes are only from reading past discussions on the old forum
2. Re: Best way to capture from VHS source
Jim_Simon Apr 18, 2009 8:20 AM (in response to lanstrad)Transfer to MiniDV first, then edit as usual.
3. Re: Best way to capture from VHS source
Ann Bens Apr 18, 2009 9:11 AM (in response to lanstrad)Your HV30 is the answer.
Hook the vcr to the camera using the av-cable supplied (the one with the yellow white and red plugs) with an extender.
Hook your camera up to the pc with firewire and you are now ready to capture the footage of the vcr into Premiere in dv-avi.
extender.jpg 8.2 K
4. Re: Best way to capture from VHS source
the_wine_snob Apr 18, 2009 6:20 PM (in response to Ann Bens)I agree with both Ann & Jim. The only expense that you will have will be the time to do the transfer to miniDV tape and the tapes (I'd strongly suggest not reusing these, but saving them in case you need to go back to them). The only benefits from the Canopus would be the correction offered by the 300, and only doing the process one time, vs a transfer to miniDV, and then a Capture to PrPro.
Please do yourself a favor and do not introduce anything DVD, except as a final output. Now, if you ALSO want an intermediate DVD for archival purposes, pick up a Panasonic (or similar) VHS-DVD machine. This is for archival purposes only.
Good luck,
Hunt
5. Re: Best way to capture from VHS source
lanstrad Apr 22, 2009 11:18 AM (in response to lanstrad)Thanks everyone for your valuable answers and guidance.
Rob
