Total Likes
Total Likes
Total Likes
Even i have the same problem...
how can we do it manually, if the list length is unknown. My task is to extract the attachments attached to the pdf form into a list. I'll not be knowing howmany attachemnts are there on the pdf form. after extraction i need to send all the documents as email attachments.
how can i do that.
Deepak
Total Likes
You have to loop throug the list and add the document one by one to the map. One more thing make sure the sub-type of map is document.
It should be three setvalue component.
(a) Initialize the Loop:
/process_data/@listCount = count(/process_data/list) ----- listCount is a variable of type int
/process_data/@currentIndex = 1 -------- currentIndex is a varibale of type int
(b) Get Current Document from List:
/process_data/@docAttach = /process_data/list[/process_data/@currentIndex] --------------- docAttach is a varibale of type document
/process_data/@docName = getDocAttribute(/process_data/@docAttach, "wsfilename") -------- docName is of type string
/process_data/@docDesc = getDocAttribute(/process_data/@docAttach, "wsdescription") --- docDesc is of type string
(c) Assign it to Map:
/process_data/mapDoc[@id=/process_data/@docName] = /process_data/@docAttach --- mapDoc is a map subtype document
/process_data/@currentIndex = /process_data/@currentIndex + 1
You have to make a condition in the Assign Map route to the Get Current Document from list.
/process_data/@currentIndex <= /process_data/@listCount
Waqas
Total Likes
Hello Rehman,
Thanks a lot for ut detailed reply.
I did not understand your latest mail... i tried the method mentioned on the old mail
Now I tried for one document.
I was very happy to see the attachement on the mail.
But the problem is when i tried to attach an image file, the image file came as an attachment, but when i tried to open, file opened but no image!! Samething happened with a text file, when i tried to open the text file on the attachment there was some crappy data istead of the actual data.
Please guide me why this is happening...
Deepak.
Total Likes
Kindly explain me in detail what your process is doing. Are you sending PDF form with attachment in an email to the customer at the end of the workflow?
How otherattachment variable is filed? Try to use variable logger to check what is inside the varibale. You can also send me you livecycle archive file.
Waqas
Total Likes
Hello Rehman,
Lets say I have three users A, B and C in the process, When the process starts some form will be displayed and A fills it and submits. It goes to B, he will attach some documents (could be jpeg, txt, pdf or anything) and submits the form. Now the flow has to extract all the documents attached to the pdf and it has to mail to C. While emailing, it has to attach all the documents along with the pdf form.
Right now I have implemented it for one attachment.
Let me explaing the steps i followed:
1. Created 2 process variables
OtherAttachmentsList - Type list - subtype Document
OtherAttachmentsMap - Type map - subtype Document
2. On the Assign task, under Attachments and Notes, I have set the output attachment variable to OtherAttachmentList
3. Before renderPDF, on the Setvalue control i have assigned OtherAttachmentsMap = OtherAttachmentsList.
I have done as you have instructed. (using docAttach, getting filename ...)
4. On the SendWithMapofDocuments control, under attachments, i have set the attachment variable as OtherAttachmentsMap
Now my problem is, I'm getting attachment on the email but the content is not proper. Can there be any problem with the mime type or the encoding standards? Or am i missing any configurations?
Since it is company related project i cant send u the .lca file. Please dont mind. And I have not understood about that DDX File. I'm a newbee.
Please guide me
Deepak
Total Likes
To extract the attachments you have to use assembler service to get the attachments from the PDF document. following is the sample DDX file that you can use to:
<?xml version="1.0" encoding="UTF-8"?>
<DDX xmlns="http://ns.adobe.com/DDX/1.0/">
<FileAttachments result="attachmentInfo.xml" nameKeys="*" extract="true">
<PDF source="fileIn1"/>
<FilenameEncoding encoding="ISO-8859-1"/>
</FileAttachments>
</DDX>
Waqas
Total Likes
Can any body please guide me...
Total Likes
I'm not sure about the step where you set the content of the map to be the content of the list : OtherAttachmentsMap = OtherAttachmentsList.
If you manually populate a map with two elements, do you get both attachments properly?
Jasmin
Total Likes
Hello Jasmin,
No i'm not getting properly for even one element on the map.
i'm doing like this:
/process_data/@docAttach = /process_data/list[1] --------------- docAttach is a varibale of type document
********Assign it to Map:************
I'm getting document in the email but not the exact data. If u send text file some crappy text file will come, and if u send some image file there will be no image on the email. But the filename everything would be same. what could be the problem?
Deepak
Total Likes
Hi
The easiest way to do this is using our CollectionUtils component.
Info here:http://avoka.dnsalias.com/confluence/display/Public/Collection+Utilities+DSC
Download here:http://www.avoka.com/avoka/escomponents.shtml
howard
Total Likes
