I use to use Adobe Premeir Pro w/my JVC camera. It took me a long time to figure out the ".MOD" problem. When I finally figured that out and burned a DVD, another problem was discovered. When ever the camera would pan in the scene the picture would get very jiddery. I found out that using video from a HD instead of Mini DV tape you had to change how the fields would be set up. I guess with HD video you must use "Upperfields First".
My question is about the same issue. I found out about deleteing ImporterFastMPEG.prm file from PE7 and imported some video files. That part worked great, but when I burned it to DVD and played it, I was back to what looked like the "Upperfields First" problem I was having in Premeir Pro. I looked around in the settings and "Upperfields" is selected but it plays like "Lowerfields First" is what it did. The reason I switched to PE7 was the fact that it could handle ".MOD" files and was a little simpler than Premeir Pro. I dont have tons of time to learn Pro right now. Thanks ahead of time if any one can shed some light on this.
By deleting or renaming ImporterFastMPEG.prm you can eliminate Media Pending error message issues but it can impact audio sync. Anyway, if you are capturing standard upper field first material you should use the project preset: "Hard Disk, Flash Memory Camcorders"... this will automatically set the field order for the project to upper field first. Likewise with the high definition presets, it will set upper field first for all the high definition project presets.
I did check and I am using the DH camcorder setting w/Upperfield first
but during play back from a DVD it looks all jiddery when the camera
is panned. It looks just like the problem I had using Pro, when the
Lowerfields first are selected. What is the difference between
capturing video on mini DV or an HD? Why do you use Lowerfields w/
mini DV and Upperfields w/HD? Thanks so much
Sent from my iPod
Can you give some more detail about your camcorder, make and model number?
Each video frame is made up of two sets of fields each field captured consectutively and interlaced, so each field captured at different times. Which field is displayed first determine if the video is upper or lower field first. By convention DV-AVI is lower field first and HDV MPEG2 is upper field first. Also, most standard definition flash memory, hard drive or DVD camcorders are upper field first. As PE7 has a DV-AVI work flow it expects lower field first video... if you use upper field first you must either use reverse field dominance or the appropriate project preset. The reason i ask your camcorder model number is to confirm that it is infact upper field first.
Thank you so much for getting back w/me so soon. The camera is a JVC
GZ-MG555u. It has a 30G hard drive and 3CCD sensors.
Sent from my iPod
Thanks for clarifying the model number, so yes, it is standard definition, .mod file format. So when you start a project you should select the "Hard Disk, Flash Memory Camcorders" project preset from the project preset list this will ensure that the field order is set correctly for your upper field first video. You should not need to adjust field order in the project timeline. A DVD exported from the project should be fine.
You say you see video judder during panning? Is this when viewed on you TV or when viewed on a monitor?
On the computer, it's perfect. On DVD on my TV is when I see it. If
the camera is still and not panning in the scene then the video is
fine. It's like the picture can't update fast enough during a pan vs a
still shot. This DVD was set up to burn upperfields first.
Sent from my iPod
Can you confirm you used the "Hard Disk, Flash Memory Camcorders" project preset. You need to maintain the correct field order through out the entire editing workflow, from importing, to editing, to burning. If you start with upper field first you need to strat with the correct project preset or correct the field order in the timeline as yoru first step. Other thing, how long is your DVD?
The test video is only 6 scenes long and about 5min in time. I'm at
work now. I'll try another test and go through all the things you told
me and get back to you. Again thank you for all your time and advice!!!
Sent from my iPod
