1. Re: Porting GoogleMapUtility to AS3
HyderAlamgir Apr 21, 2009 8:05 PM (in response to HyderAlamgir)Ok, no answers yet.
In any case, I've fixed the internal build error.
Now, the calculations are all messed up. I get different results from calling the PHP function and different ones from calling the ported function in AS3.
Anyone?!
2. Re: Porting GoogleMapUtility to AS3
_Natasha_ Apr 21, 2009 11:14 PM (in response to HyderAlamgir)It's will bw easier to help if you write call parameters for functions and results for AS and PHP
3. Re: Porting GoogleMapUtility to AS3
brock.haywood Nov 3, 2010 1:20 PM (in response to HyderAlamgir)You have errors in your rad2deg and deg2rad methods.
Here is the fixed class:
package com.google.maps
import flash.geom.Point;
import flash.geom.Rectangle;
public class GoogleMapsUtility
public static const TILE_SIZE:int = 256;
public static var normalised:Point = new Point(-1, -1);
public static var pixelCoords:Point;
public static var scale:Number = 1;
public static function fromXYToLatLng( point:Point, zoom:int ):Point
scale = ( 1 << (zoom)) * GoogleMapsUtility.TILE_SIZE;
// CORRECT: Where does normalised come from?! //
return new Point( int( GoogleMapsUtility.normalised.x * scale), int( GoogleMapsUtility.normalised.y * scale) );
return new Point( pixelCoords.x % GoogleMapsUtility.TILE_SIZE,
pixelCoords.y % GoogleMapsUtility.TILE_SIZE );
public static function fromMercatorCoords( point:Point ):Point
point.x *= 360;
point.y = GoogleMapsUtility.rad2deg( Math.atan( GoogleMapsUtility.sinh( point.y )) * Math.PI );
return point;
public static function sinh( x:Number ):Number
return ((Math.exp(x) - Math.exp(-x)) / 2.0);
public static function rad2deg( rad:Number ):Number
return (rad * 180 / Math.PI);
public static function deg2rad( deg:Number ):Number
return (deg * Math.PI / 180);
public static function getPixelOffsetInTile( lat:Number, lng:Number, zoom:Number ):Point
pixelCoords = GoogleMapsUtility.toZoomedPixelCoords( lat, lng, zoom);
public static function getTerminalPixelOffsetInTile( lat:Number, lng:Number, zoom:Number,
rot:Number, len:Number ):Point
var endlng:Number = lng + ( len / ( 3 * 9500 )) * Math.cos( GoogleMapsUtility.deg2rad( rot ));
var endlat:Number = lat + ( len / ( 3 * 9500 )) * Math.sin( GoogleMapsUtility.deg2rad( rot ));
var newpt:Point = GoogleMapsUtility.getPixelOffsetInTile( endlng, endlat, zoom );
return newpt;
public static function getTileRect( x:Number, y:Number, zoom:Number ):Rectangle
// CORRECT: What types to use here -- Number?
var tilesAtThisZoom:Number = 1 << zoom;
var lngWidth:Number = 360.0 / tilesAtThisZoom;
var lng:Number = -180 + ( x * lngWidth );
var latHeight:Number = 2.0 / tilesAtThisZoom;
var lat:Number = (( tilesAtThisZoom / 2 - y - 1 ) * latHeight );
/** convert lat and latHeight to degrees in a transverse mercator projection
* note that in fact the coordinates go from about -85 to +85 not -90 to 90! */
latHeight += lat;
latHeight = ( 2 * Math.atan( Math.exp( Math.PI * latHeight ))) - ( Math.PI / 2 );
latHeight *= ( 180 / Math.PI );
lat = ( 2 * Math.atan( Math.exp( Math.PI * lat ))) - ( Math.PI / 2 );
lat *= ( 180 / Math.PI );
latHeight -= lat;
if ( lngWidth < 0 )
lng = lng + lngWidth;
lngWidth = -lngWidth;
if ( latHeight < 0 )
lat = lat + latHeight;
latHeight = -latHeight;
$latHeightMerc = 1.0 / $tilesAtThisZoom;
$topLatMerc = $y * $latHeightMerc;
$bottomLatMerc = $topLatMerc + $latHeightMerc;
$bottomLat = (180 / M_PI) * ((2 * atan(exp(M_PI *
(1 - (2 * $bottomLatMerc))))) - (M_PI / 2));
$topLat = (180 / M_PI) * ((2 * atan(exp(M_PI *
(1 - (2 * $topLatMerc))))) - (M_PI / 2));
$latHeight = $topLat - $bottomLat;
return new Rectangle( lng, lat, lngWidth, latHeight );
public static function toMercatorCoords( lat:Number, lng:Number ):Point
if ( lng > 180 ) {
lng -= 360;
lng /= 360;
lat = GoogleMapsUtility.invhypsin( Math.tan( GoogleMapsUtility.deg2rad( lat ))) / Math.PI/2;
/**$lat = 0.5 - ((log(tan((M_PI / 4) + ((0.5 * M_PI * $lat) / 180))) / M_PI) / 2.0);*/
return new Point( lng, lat );
public static function toNormalisedMercatorCoords( point:Point, z:Number ):Point
point.x += 0.5;
point.x *= z ^ 2;
point.y = Math.abs( point.y - 0.5 );
point.y *= z^2;
return point;
public static function toZoomedPixelCoords( lat:Number, lng:Number, zoom:int ):Point
var pt:Point;
pt = GoogleMapsUtility.toNormalisedMercatorCoords(
GoogleMapsUtility.toMercatorCoords( lat, lng ), zoom );
GoogleMapsUtility.normalised.x = pt.x;
GoogleMapsUtility.normalised.y = pt.y;
GoogleMapsUtility.scale = ( 1 << ( zoom )) * GoogleMapsUtility.TILE_SIZE;
return new Point( int( GoogleMapsUtility.normalised.x * GoogleMapsUtility.scale ), int( GoogleMapsUtility.normalised.y * scale ));
public static function invhypsin( z:Number ):Number {
return Math.log( z + Math.sqrt( z^2 + 1 ));
