Dear all,
Under Eclipse Version: 3.3.0 I have installed the workbench ES SP2
Update : I did the same with a fresh install of eclipse 3.2.1
Update2 : Did the same with the workbench
Whenever I try to create a new compennent category under 7.x compenent view I get an exception : java.lang.OutOfMemoryError: Java heap space
Here is my eclipse.ini
-showlocation
-vm
C:\bea920\jdk150_04\bin\javaw.exe
-vmargs
-XX:+UseParallelGC
-XX:PermSize=24M
-XX:MaxPermSize=128M
-XX:NewSize=32M
-XX:MaxNewSize=64M
-Xverify:none
-Xms512m
-Xmx900m
Update :
Following ecplise.ini doesn't work
-showlocation
-vmargs
-Xms256M
-Xmx1024M
I tried to monitor my ecplise process with jconsole and it doesn't show a big increase in memory usage.
Is a new java process launched ?
If so it doesn't take into account my Installed JRE default VM arguments (-Xmx768m) ....
Any idea ?
Caused by: java.lang.OutOfMemoryError: Java heap space ; nested exception is:
at org.apache.axis.message.SOAPFaultBuilder.createFault(SOAPFaultBuilder.java:221)
at org.apache.axis.message.SOAPFaultBuilder.endElement(SOAPFaultBuilder.java:128)
at org.apache.axis.encoding.DeserializationContext.endElement(DeserializationContext.java:1087)
at org.apache.xerces.parsers.AbstractSAXParser.endElement(Unknown Source)
at org.apache.xerces.impl.XMLNSDocumentScannerImpl.scanEndElement(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
at org.apache.xerces.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:375)
at org.apache.axis.encoding.DeserializationContext.parse(DeserializationContext.java:227)
at org.apache.axis.SOAPPart.getAsSOAPEnvelope(SOAPPart.java:696)
at org.apache.axis.Message.getSOAPEnvelope(Message.java:424)
at org.apache.axis.handlers.soap.MustUnderstandChecker.invoke(MustUnderstandChecker.java:62)
at org.apache.axis.client.AxisClient.invoke(AxisClient.java:206)
at org.apache.axis.client.Call.invokeEngine(Call.java:2765)
at org.apache.axis.client.Call.invoke(Call.java:2748)
at org.apache.axis.client.Call.invoke(Call.java:2424)
at org.apache.axis.client.Call.invoke(Call.java:2347)
at org.apache.axis.client.Call.invoke(Call.java:1804)
at com.adobe.idp.dsc.provider.impl.soap.axis.sdk.SoapAxisDispatcher.doSend(SoapAxisDispatcher.java:123)
... 46 more
Total Likes
I have recorded with fiddler the traffic between eclipse and the server (soap requests and answers)
The answer is :
<?xml version="1.0" encoding="utf-8"?>
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<soapenv:Body>
<soapenv:Fault><faultcode>soapenv:Server.generalException</faultcode>
<faultstring>java.lang.OutOfMemoryError: Java heap space; nested exception is:
java.lang.OutOfMemoryError: Java heap space</faultstring>
<detail><ns1:hostname xmlns:ns1="http://xml.apache.org/axis/">XXXXXXXXX</ns1:hostname></detail></soapenv:Fault>
</soapenv:Body>
</soapenv:Envelope>
So I have an OutOfMemory on the server !
There is no trace of on an outofmemory on the server ... strange !
If I switch from -Xmx1024m to - Xmx2048m on the server
The server is able to respond BUT
The soap answer is around 100Mb
My eclipse cannot handle this
So my question is answered : I know that this OutOfMemory comes from the server
So my question is not answered : The server returns to much information
Total Likes
Hello,
I am using the following version:
My configuration:
Hardware: Intel Core 2 Quad - Q9550 - 2.83 Ghz - 4Go of RAM - 32 bits (this is a new workstation computer).
Software: Windows XP pro service pack 3.
JBoss for Adobe LiveCycle ES - Jboss Livecycle version 8.2 with SP2 of LiveCycle ES and Workbench.
MySQL for Adobe LiveCycle ES
In fact, I meet the same problem.
!ENTRY com.adobe.DSC_Admin_UI 4 4 2009-05-25 14:33:31.114
!MESSAGE failed to retrieve list of components
!STACK 0
ALC-DSC-000-000: com.adobe.idp.dsc.DSCRuntimeException: Internal error.
at com.adobe.idp.dsc.provider.impl.soap.axis.sdk.SoapAxisDispatcher.throwExceptionHandler(SoapAxisDispatcher.java:207)
at com.adobe.idp.dsc.provider.impl.soap.axis.sdk.SoapAxisDispatcher.doSend(SoapAxisDispatcher.java:125)
at com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(AbstractMessageDispatcher.java:57)
at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:208)
at com.adobe.idp.dsc.registry.component.client.ComponentRegistryClient.invoke(ComponentRegistryClient.java:373)
at com.adobe.idp.dsc.registry.component.client.ComponentRegistryClient.getComponents(ComponentRegistryClient.java:63)
at com.adobe.dsc.contentprovider.MixedRegistryContentProvider$RegistryRootEntry.getChildren(MixedRegistryContentProvider.java:150)
at com.adobe.dsc.contentprovider.MixedRegistryContentProvider.getChildren(MixedRegistryContentProvider.java:575)
at org.eclipse.jface.viewers.AbstractTreeViewer.getRawChildren(AbstractTreeViewer.java:1166)
at org.eclipse.jface.viewers.TreeViewer.getRawChildren(TreeViewer.java:768)
at org.eclipse.jface.viewers.AbstractTreeViewer.getFilteredChildren(AbstractTreeViewer.java:574)
at org.eclipse.jface.viewers.AbstractTreeViewer.getSortedChildren(AbstractTreeViewer.java:543)
at org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractTreeViewer.java:728)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:67)
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren(AbstractTreeViewer.java:705)
at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeViewer.java:892)
at org.eclipse.jface.viewers.AbstractTreeViewer.handleTreeExpand(AbstractTreeViewer.java:1251)
at org.eclipse.jface.viewers.AbstractTreeViewer$4.treeExpanded(AbstractTreeViewer.java:1263)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:181)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:952)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:937)
at org.eclipse.swt.widgets.Tree.wmNotifyChild(Tree.java:6343)
at org.eclipse.swt.widgets.Control.WM_NOTIFY(Control.java:3794)
at org.eclipse.swt.widgets.Composite.WM_NOTIFY(Composite.java:1166)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3298)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4025)
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:1851)
at org.eclipse.swt.widgets.Tree.callWindowProc(Tree.java:1321)
at org.eclipse.swt.widgets.Tree.WM_LBUTTONDOWN(Tree.java:5203)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3279)
at org.eclipse.swt.widgets.Tree.windowProc(Tree.java:4783)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:1932)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:2966)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:1930)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1894)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:422)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at com.adobe.lcide.rcp.Application.run(Unknown Source)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(PlatformActivator.java:78)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:92)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:68)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:177)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336)
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Caused by: java.lang.OutOfMemoryError: Java heap space; nested exception is:
at javax.xml.parsers.SAXParser.parse(SAXParser.java:395)
... 54 more
The list of components is not displayed in the Workbench ES.
This happens when we don't restart the server for a long while.
I have 2 computer: one for the Server ES and for Eclipse, one for the workbench.
In the error trace, we see that the AXIS webservice can not parse a XML stream. When analysing the HTTP Stream, we see that the server send some text which begin with:
<?xml version="1.0" encoding="UTF-8"?><soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><soapenv:Body><ns1:invokeResponse soapenv:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:ns1="http://sdk.axis.soap.impl.provider.dsc.idp.adobe.com"><invokeReturn xsi:type="soapenc:base64Binary" xmlns:soapenc="http://schemas.xmlsoap.org/soap/encoding/">rO0ABXNyADVjb20uYWRvYmUuaWRwLmRzYy5wcm92aWRlci5pbXBsLmVqYi5FamJSZXNwb25zZUhvbGRlcgAAAAAN9dBdAgAAeHIAO2NvbS5hZG9iZS5pZHAuZHNjLnByb3ZpZGVyLmltcGwuYmFzZS5BYnN0cmFjdFJlc3
AND They don't end with an XML tag : the XML is not valid !!!
Thank you
Total Likes
