hi...
I made a process for pre-filling a form. The steps included: getting data from database in an XML, applying XSLT and rendering a PDF form.
XSLT is used to avoid the dependence of the process on a form.
Now, the scenario is changed, the data to be pre-filled i.e. the XML will be generated from a webservice on fragments basis which implies if a form has 20 fragments, 20 XML's will be generated. (Hope, I made myself clear!!!!!!)
I thought of using XSL again for making one XML for pre-filling data. But XSLT takes one XML as an input.
Can anyone suggest me, should I make one XSL for the form or should I make XSL's as per fragments. Next, how could I merge all these XMLs to generate one XML for pre-filling.?
Please, also suggest me, if there is any other workaround for this scenario?
Thanks and Regards,
Ambika Mittal
Total Likes
Hi Ambika
I'm not sure about your exact scenario, but you could try XQuery intead of XPath.
Info here:
http://avoka.dnsalias.com/confluence/display/Public/Transforming+XML+Documents
http://www.avoka.com/blog/?s=xquery
and http://avoka.dnsalias.com/confluence/display/Public/XQuery+DSC
Download here:http://www.avoka.com/avoka/escomponents.shtml
XQuery is quite a lot more powerful than XSLT (in my opinion).
In addition, our implementation allows you to merge multiple XML documents together.
Please contact info@avoka.com if you have any problems...
Howard
Total Likes
