Concatenating if statements
Dec 13, 2006 Dec 13, 2006
I have 44 if statements the results i would like to have is this my loop goes throught the 44 statements to see if any of them are true.
what i want is if there is more than on of them that are true then to out put them for some reason it only outputs 1
I would also like to concatenate them all if more than one
here is my code:
Advanced techniques
576
Community Beginner , Dec 15, 2006 Dec 15, 2006
I think I misunderstood what you're trying to do. Are you just pulling one row from a table and trying to display the value if one exists for the field?
I'm also kind of thrown off by your <cfloop> that always only loops one time. What's the point of it?
The reason is that you are uisng cfelseif. Once the first condition is satisfied, no more elseif's run.
so if i just used the cfif statement one after the other it should work?
quote:
Probably.
What happened when you tried it?
Dec 14, 2006 Dec 14, 2006
it only shows the first one it finds
I think it may have something to do with my loop
I only loop on the CfgDisplay
here is the loop
<cfloop index="loopcount" from="1" to="1">
<font size="+1"><strong>#CfgDisplay#</font></strong><p>
</cfloop>
should I be looping through all of the code or is this ok?
You are resetting CfgDisplay within each <cfif> block, so its value will always be the value of the last <cfif> block that executes.
Maybe this would work for you: set CfgDisplay to an empty string before all cfif blocks, then use ListAppend() within each block so at the end you'll have a list of values.
nope didn't work
this is the result it gives me
58340008 Front 2 Suspension Stabilizer Bar Link Kit
Use With: DriveType: RWD SubModel: DLX
58340005 Front Left 1 Suspension Stabilizer Bar Link Kit
Use With: DriveType: RWD SubModel: DLX DriveType: 4WD
Use With: DriveType: RWD SubModel: DLX DriveType: 4WD DriveType: RWD SubModel: Pre Runner
58340006 Front Right 1 Suspension Stabilizer Bar Link Kit
Use With: DriveType: RWD SubModel: DLX DriveType: 4WD DriveType: RWD SubModel: Pre Runner DriveType: 4WD
Use With: DriveType: RWD SubModel: DLX DriveType: 4WD DriveType: RWD SubModel: Pre Runner DriveType: 4WD DriveType: RWD SubModel: Pre Runner
there should only be one drive type per number and one sub model
but they seem to keep repeating themselves
Documentation
