Show 1 reply
1. Re: PE4 Crash ~ ippmpegdecoder is the Culprit...
Bill Hunt Apr 22, 2009 6:33 PM (in response to Kodebuster)If the MainConcept CODEC is broken, a Repair Install should reinstall that element and then you should be good to go. I will say that MPEG is tougher to edit, than DV-AVI Type II files. Personally, I always convert via a 3rd party program. Since I edit SD material only, I do not have to worry about MP4 and AVCHD files.
As most MPEG material is not really designed to be edited (it is a delivery format), as it is a compressed GOP format with I-frames and P-frames (difference frames) it needs to be converted either internally (PE), or externally.
Good luck,
Hunt
