1. Re: A malfunction puzzler, and I'm hitting a deadline
Bill Hunt Apr 22, 2009 8:30 PM (in response to SplineTimeLine)Ken,
Your Project is intact - good move. I'd immediately do a Save_As and work on that. Try opening AE and minimizing it. Then attempt your edits, as you desire. Hope that the results are what you want.
Maybe others will have some different things to try.
Good luck,
Hunt
2. Re: A malfunction puzzler, and I'm hitting a deadline
Kevin Pavlovic Apr 23, 2009 11:20 AM (in response to SplineTimeLine)Hi, I had a similar thing happen to me, and what was causing it in my particular project was that I had an audio clip in my timeline that I had disabled. It was the only clip on the track, the track was on the bottom layer, and there was about 6 audio tracks (I can't remember if the track was mono or stereo - project was stereo). When I re-enabled this one clip, everything would play as it should, and disabling it again would not allow me to play the project.
I wasn't able to replicate this in other projects so I'm not sure what the exact cirumstances are that add up to cause this issue, but maybe you are experiencing something similar?? Check and see that all your clips are enabled.
Good luck!
