1. Re: Can't transcode a project - constant error messages
Bill Hunt Apr 25, 2009 2:53 PM (in response to jesskaat)Jessica,
Can you tell us a bit more about your Project? What version of En are you using, and if CS3, or CS4, how are you getting your Assets to En? Along those lines, if you are doing an Export from PrPro, what file formats are you Exporting as, prior to Import into En?
Have you tried an Export from PrPro as DV-AVI elemental stream and either PCM/WAV, or AC3 elemental stream for Audio? If not, try this as a "test."
I also have to comment that a 7 hr. Transcode is not the norm. Using DV-AVI and AC3's, I get full DVD-9 Transcode in half over real time, i.e. a 4 hour DVD-9 will usually Transcode in a little less than 6 hrs. With a 1 hr. Duration, something is not right, unless your computer is horribly slow. What are your system specs.?
Good luck,
Hunt
[Edit] it also appears that the error (is this in En, or PrPro?) to be coming from either the muxing (PrPro), or de-muxing (En) process, as the .XMPES file is most often used to mux an MPEG file. That has me puzzled.
