I may just be really tired, but I'm just not getting this. What I'm trying to accomplish is to output a query, and as it's outputting, check a list to see if a value exists, and if so, change the class of a <li>
I have two queries and am defining a list from one:
<cfquery name="rsTags" datasource="cfsfwer">
SELECT tags.tagName, tags.tagsID
FROM tags, blogTagLink
WHERE blogTagLink.blogID = <cfqueryparam value="#SESSION.blogID#" cfsqltype="cf_sql_numeric">
AND tags.tagsID = blogTagLink.tagID
</cfquery>
<cfset selectedTags = ValueList(rsTags.tagsID)>
<cfquery name="rsAllTags" datasource="cfsfwer">
SELECT *
FROM tags
ORDER BY tags.tagName
</cfquery>
So far this works just fine. The output of #selectedTags# is correct. Now I want to output #rsAllTags# and check to see if the record is ALSO in the #selectedTags# list, and if it is, change the class on the output, like this
<ul>
<cfoutput query="rsAllTags">
<cfset temp = ListFind(selectedTags, #rsAllTags.tagsID#)>
<cfif temp EQ 0>
<li class="tagnotselected""><a>#rsAllTags.tagName#</a></li>
<cfelse>
<li class="tagselected""><a>#rsAllTags.tagName#</a></li>
</cfif>
</cfoutput>
</ul>
It doesn't work, and it is related to the variable #rsAllTags.tagsID#. If I use a static value for this, it works fine. Obviously, I need a dynamic value to deal with the output query.
Any help would be appreciated.
If your db supports it, this type of query will give you exactly what you want and simplify your output.
select tagid, tagname,
case when x.tag_id is not null then 'tagselected' else 'tagnotselected' end included
from tags left join (
select tagid
from tagblocklink
where tagid = = <cfqueryparam value="#SESSION.blogID#" cfsqltype="cf_sql_numeric">
) x on tags.tagid = x.tagid
order by tagname
The output should require no if/else logic
select tagid
from tagblocklink
order by tagname
I'm using MYSQL, and I am not sure. Thanks for putting this up, but, honestly that answer is a little over my head. I'm struggling to follow it
run it and dump it. make sure you delete the extra equal sign first
Thanks Dan:
I get errors when trying to run this. The first is:
Unknown column 'x.tag_id' in 'field list'
I know that this is the right approach, just not sure how to get it
working.
This is what I'm running:
<cfquery name="rsTags" datasource="committedsardine"> select tagid, tagname, case when x.tag_id is not null then 'tagselected' else 'tagnotselected' end included from tags left join ( select tagid from blogTagLink where tagid = <cfqueryparam value="#SESSION.blogID#" cfsqltype="cf_sql_numeric">) x on tags.tagid = x.tagid
order by tagname
</cfquery
Dan:
Thank you so much for your expert help. After working at this for a
while, I understood what was going on, made some corrections and got
it to work. It is obvious to me that I need to spend more time
learning SQL!. Thank you for taking the time to help. Here is the
final code:
<cfquery name="rsNewTags" datasource="committedsardine">
case when x.tagid is not null then 'tagselected' else 'tagnotselected' end included
select tagID
from blogTagLink
where blogID = <cfqueryparam value="#SESSION.blogID#" cfsqltype="cf_sql_numeric">
) x on tags.tagsID = x.tagid
order by tagname
</cfquery>
The cfdump for rsNewTags is this:
INCLUDED TAGID TAGNAME
1 tagnotselected empty string assessment
2 tagselected 5 brain
3 tagnotselected empty string collaboration
4 tagselected 10 digital
5 tagnotselected empty string digital diet
6 tagnotselected empty string evaluation
7 tagselected 4 exponential
8 tagselected 6 fluency
9 tagnotselected empty string global
10 tagnotselected empty string hardware
And the conditional statement is now this:
<cfoutput query="rsNewTags">
<cfif rsNewTags.included EQ "tagselected">
<li class="tagselected"><a>#rsNewTags.tagName#</a></li>
<cfelse>
<li class="tagnotselected"><a>#rsNewTags.tagName#</a></li>
</cfif>
</cfoutput>
Regarding
<cfelse>
</cfif>
</cfoutput>
too much work. all you need is
<li class="#something from your query#"><a>#rsNewTags.tagName#</a></li>
Wow, right you are. I totally get it now. Thanks so much, works like
a charm.
You need use the valuelist() function around your query.column to convert the record set into a list before you can search it.
First try it witout the pound signs, those are unnecessary.
<cfset temp = ListFind(selectedTags, rsAllTags.tagsID)>
And then it is possible that you are not fully referencing the query record set and so you are only getting the first row for each iteration. If so try this.
<cfset temp = ListFind(selectedTags, rsAllTags.tagsID[rsAllTags.currentRow])>
Thanks Ian:
I tried both of those and neither works. The problem is definitely
related to the current row for me because when I output the variable
#temp#, I am getting a list of results. This tells me that it is
running all the instances of rsAllTags.tagsID and not just the current
one. I don't know how to get around it. I thought that your last
suggestion:
would work, but it gives the same output.
I would then output each part of the function and the function results for each itteration, or a sub-set of itterations if it is a large result set.
Check that each part and the results are as expected.
