2 Replies Latest reply: Apr 24, 2009 3:24 AM by jsriram RSS
    LiveCycle Designer ES alignment issues...
    jsriram Community Member
      I have created few forms in Adobe Output Designer (IFD). I have converted those Adobe Output Designer (IFD) files to Adobe Livecycle ES (XDP). I have successful converted those IFD files to XDP, but I found some alignment problems in XDP files.
      It’s not matching 100% with the IFD files.
      Any suggestions are welcome.....
      Jayakumar Sriram
        • 1. Re: LiveCycle Designer ES alignment issues...
          Carl Young Community Member
          I am not clear on exactly what kind of alignment problems you have. The first place to look is in the Layout palette for individual fields, then also the paragraph palette. A dynamic subform could be causing fields to rearrange/realign, and then there is always snap to grid. If these suggestions don't help, perhaps you could provide some more specifics.
          Carl
          • 2. Re: LiveCycle Designer ES alignment issues...
            Hi Carl,
            Thanks for your response.
            When we compare the printouts between Adobe output Designer(IFD) and Adobe livecycle designer ES (XDP), there seems to be difference appx 0.030 (X axis) and 0.064 (Y axis). But the position in output designer and livecycle designer are same for both. Every form we are adjusting the positions and compare the results between adobe output designer and LC designer.
            Thanks in advance.
            Jayakumar Sriram
