17 Replies Latest reply: May 7, 2009 5:26 AM by sudar1983_14 RSS
    Export JPEG
    Ken Krugh Community Member
      I'm working in CS3, Windows, VB. Can anyone tell me why this code won't produce a file?
      The only other thing I've tried is Ind.Selection(1).Export with these same parameters, which produces a file but only at 72 dpi, not a 900 dpi as I set in the JPEGExportPreferences.
          Set Ind = CreateObject("InDesign.Application.CS3")
          Set IDoc = Ind.ActiveDocument
          With Ind.JPEGExportPreferences
              .ExportingSpread = False
              .JPEGExportRange = idExportAll
              .JPEGQuality = idJPEGOptionsQuality.idHigh
              .JPEGRenderingStyle = idBaselineEncoding
              .PageString = "3"
              .Resolution = 900
          End With
          IDoc.Export idExportFormat.idJPG, "c:\jgpfile.jpg", False
      Thanks for the help,
      Ken
        • 1. Re: Export JPEG
          sudar1983_14 Community Member
          In CS3 there is no option to convert selected item to jpeg with preferences (CS3 bug)
          So, You have to resize the page to jpg size and then export with page as jpg.
          Sudar
          • 2. Re: Export JPEG
            pkahrel Community Member
            That's not true: in CS3, in JavaScript, app.jpegExportPreferences.resolution = 300 works fine. Maybe it's a VB problem.
            Peter
            • 3. Re: Export JPEG
              Is it your code working fine then can you please send your code. I have a problem with my code.
              aDoc=app.activeDocument;
              selTextFrame=aDoc.pages.item(0).textFrames.item(0);
              app.jpegExportPreferences.resolution = 300;
              selTextFrame.exportFile(1246775072, "D:\\test.jpg", false);
              Sudar
              • 4. Re: Export JPEG
                Your code works fine. What's your problem?
                Peter
                • 5. Re: Export JPEG
                  No file gets produced. The only way I've been able to produce a file is by using the export command on the selection object. But THEN, the JPEG export preferences seem to be ignored.
                  • 6. Re: Export JPEG
                    Maybe you need a file object rather than a string. In JS you create a file object like this: File ('d:\\test.jpg'). I'd have expected that this was required in JS, but it worked on a simple string as well as on a file object. Maybe VB needs a file object.
                    Peter
                    • 7. Re: Export JPEG
                      Hi Peter,
                      It is javascript code.
                      It will produce a file, but the resolution is 72. Here the question is, it will support the preferences or not?
                      Sudar
                      • 8. Re: Export JPEG
                        Hi Ken,
                        This is the code for VB, You have to set jpg size to the page and then export page as jpg then you get what you are expected.
                        Here oFigureGroup is the selected item, oInDoc is the indesign document, olPg is the current page
                        oFOGeo = oFigureGroup.GeometricBounds
                        oPgHeight = oInDoc.DocumentPreferences.PageHeight
                        oPgWidth = oInDoc.DocumentPreferences.PageWidth
                        oInDoc.DocumentPreferences.PageHeight = oFigureGroup.GeometricBounds(2) - oFigureGroup.GeometricBounds(0)
                        oInDoc.DocumentPreferences.PageWidth = oFigureGroup.GeometricBounds(3) - oFigureGroup.GeometricBounds(1)
                        oFigureGroup.GeometricBounds = oIPg.Bounds
                        oIndsn.JPEGExportPreferences.Resolution = 300
                        oIndsn.JPEGExportPreferences.JPEGExportRange = idExportRangeOrAllPages.idExportRange
                        oIndsn.JPEGExportPreferences.PageString = oIPg.Name
                        oInDoc.Export idExportFormat.idJPG, "d:\test.jpg", False
                        oInDoc.DocumentPreferences.PageHeight = oPgHeight
                        oInDoc.DocumentPreferences.PageWidth = oPgWidth
                        oFigureGroup.GeometricBounds = oFOGeo
                        Please let me know any other requires.
                        sudar
                        • 9. Re: Export JPEG
                          SuperMacGuy Community Member
                          I had reported about 6 months ago that Applescript, on exporting selection, ignores the preferences. It was confirmed as a bug by an Adobe engineer, to me directly. I guess it also affects VB. As stated by another poster, you have to export the entire page to use the export preferences/dpi/quality/etc.
                          • 10. Re: Export JPEG
                            Well, JavaScript in CS3 and CS4, on Windows XP, exports the referenced text frame as expected, i.e. Sudhar's code works fine for me.
                            Peter
                            • 11. Re: Export JPEG
                              Ah OK, it's just an Applescript bug then. Thanks for (re) clarifying.
                              • 12. Re: Export JPEG
                                Hi All,
                                In Javascript it will produce a jpg file, there is no doubt about it, but jpgpreferences are ignored, so resolution should be 72 only. It is actually Indesign CS3 bug.
                                regards,
                                sudar
                                • 13. Re: Export JPEG
                                  Sudar,
                                  Again, you're wrong: Bridge and PhotoShop tell me that the JPEG of exported referenced frame (using the literal code you posted earlier) has the resolution set in the script. How do you determine the resolution of the exported file?
                                  Peter
                                  • 14. Re: Export JPEG
                                    Dave Saunders Community Member
                                    Peter,
                                    Where's your passion? Sudar is shouting very loudly. I wonder if you are being heard at all.
                                    Sardonic grin.
                                    Dave
                                    • 15. Re: Export JPEG
                                      Hi Peter,
                                      Im using Irfan view to see the resolution.
                                      sudar
                                      • 16. Re: Export JPEG
                                        AdobeScripts Community Member
                                        ROTFL
                                        IrfanView isn't Maste-Of-All-Graphics-Applications
                                        so you should check your file in other applications before you shout so loud
                                        robin
                                        www.adobescripts.co.uk
                                        • 17. Re: Export JPEG
                                          Hi Adobe,
                                          This is my code,
                                          Plese find the attachment, ie exported jpg file.
                                          sudar
