Hi guys, i inserted an flv video with the playbar into my captivate slide. i set it to rewidn after it plays. and the duration for "rest of slide" however, after the end of the video, the video windows disappears from the slide. ideas?
select you flv file on your stage. Select Options tab. make sure your video is not on 'fade in and out'. Select no transition.
this should solve your problem.
the video was set up to "fade in" only and it still faded out. To fix the issue, i changed the movie to "no transition"
