Is there a way to dynamically get the topic title? I want to have a table near the top of each page which automatically displays the topic title in the first cell.
Insert > Fields and Variables.
You could try using that with a Master Page as well.
In RH7, if you use a template, RH automatically inserts a variable for the title in topics that are created using the template. I expect you can create a template with a table and move that variable into the table, and then in topics you create from the template, the table and title will show up. Whenever you change the topic title in the topic properties, it will automatically update in the topic itself.
Ben
