1. Re: Large Print Image
Simon Steele Apr 28, 2009 9:49 AM (in response to Simon Steele)Any Help would be greatly appreciated.
2. Re: Large Print Image
Gyno-jiz Apr 28, 2009 9:51 AM (in response to Simon Steele)Logos should be done in Illustrator. While a vector file can be created in PS, sign printers in particular might have trouble with the format. Illustrator was designed for logo creation, PS was not.
3. Re: Large Print Image
John Danek Apr 29, 2009 8:05 AM (in response to Simon Steele)I agree with J. Maloney. Absolutely not Photoshop, the file size may become unmanageable, depending on final resolution. The advantage to Illustrator is that it will be a vector file which can be sized up or down seamlessly. You could setup your document 3x3, but that may give you an unrealistic perspective when drawing. I usually start with a sketch around 3"x5" and scan it grayscale. Then, I'll "Place" the scan ( dim @ 50% ) and create a drawing layer over it. When done, save a flattened copy ( or not ) as CMYK and then, copy & paste that into your final 3x3 file where it can be sized up appropriately.
