i am getting [RPC Fault faultString="HTTP request error" faultCode="Server.Error.Request" faultDetail="Error: [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032"] error while trying to call a htttpservice.
the following is the code which i am using to call the httpservice. my flex app and the http service which i am trying to call is located on the same server. if i paste the URL in the browser and click enter i was able to retreive the data.
but when i use the same URL in the flex its not working. i tried using an application called HTTPanalyzer which logs all the http requests
made by all the applications.but i couldnt find the flex app making any call to the server at all. i.e. its not actually sending request at all.please help me
<?xml version="1.0" encoding="utf-8"?>
<mx:TitleWindow xmlns:mx="http://www.adobe.com/2006/mxml">
<mx:Script>
<![CDATA[
import mx.controls.*;
import mx.collections.*;
import mx.managers.PopUpManager;
import mx.core.Application;
import mx.events.*;
[Bindable]
private function passKeys():void{
var params:Object={};
params["bu"]=bu.text.toUpperCase();
params["poid"]=poID.text.toUpperCase();
params["poget"]=Application.application.poadd.poMetaData.toXMLString();
Alert.show(http_createPO.url);
Application.application.mode="A";
http_createPO.send(params);
</mx:Script>
<mx:HTTPService id="http_createPO" showBusyCursor="true" url="http://xxxx.com/WEBLIB_FX_DOC.SM_FX_PO.FieldFormula.IScript_createPO" result="Application.application.getPO(event)" resultFormat="xml" fault="Alert.show(event.fault.toString())"/>
<mx:Button x="134" y="68" label="Create PO" id="createPO" click="passKeys()"/>
<mx:TextInput x="166" y="11" id="bu" keyUp="autocomplete(this.bu,event)" fontWeight="bold"/>
<mx:TextInput x="166" y="37" id="poID" text="Next" fontWeight="bold" maxChars="8"/>
</mx:TitleWindow>
Total Likes
That looks like a security error, check if your app is running within the same url root that your httpservice.
Total Likes
Did you compile with --use-network=true?
Total Likes
Thanks for the reply guys.
i had it working.i have not changed anything from the code perspective i tried deleting browser cache and server cache.but its working only on some machines..any iddea guys?
Total Likes
