Hi wiz
Basically, you need to edit the rhbag.apj file with your
project closed. It's a pain but works, just backup your project
before you start. As Rick says, follow the instructions but delete
the the file from the rhbag.apj file. I vaguely seem to recal a
trick of renaming the file that appears in the baggage folder
before trying to delete it. Good luck.
From Pete's site:
"In X5, in addition to the usual way of adding baggage files,
you can edit the rhbag.apj file. With the project closed, open the
file in a text editor such as Notepad and copy / paste an existing
section. Replace the name of the baggage file with the new one.
When adding javascript files to topics, RH should
automatically add them to baggage. Often it does not. To avoid
having to edit the rhbag.apj file in such cases, I add the js file
to baggage manually before inserting the reference. In the long
run, it's easier."
