Show 3 replies
1. Re: Door Poster
Gyno-jiz Apr 28, 2009 2:09 PM (in response to Simon Steele)You can do either. Whatever you, or your printer, are comfortable with.
2. Re: Door Poster
John Danek Apr 29, 2009 8:16 AM (in response to Simon Steele)If you have a bleed, you'll need trim marks. Should have them anyway. Let's say your final door size is 36x80 vertical. I would setup your document at 40x84, enough room for trim marks, center marks, file information, bleed, color bars, etc. I do not use software based trim marks, but you can if you want to. Sounds like large format, so Illustrator should be sufficient.
3. Re: Door Poster
Simon Steele Apr 29, 2009 9:50 PM (in response to Simon Steele)awesome thanks guys, Ya I desigined it all in Illustrator so it is resolution independent.
