8 Replies Latest reply on Apr 30, 2009 9:32 PM by Flex harUI
    Get the origin of dispatched Event
    drillnaut
      Hello Everyone,
        I am using a custom event for a class that I have made.  In the main class , I add a listener to the aforementioned objects of the class.  When the event is fired and caught, I need to know exactly which one of my objects has dispatched the event.  I have tried casting the event to the class
      list:Mylist = event.currentTarget as Mylist.
      However , flex builder won't let that slide.  Any help is greatly appreciated.
      Sincerely,
        JD
        • 1. Re: Get the origin of dispatched Event
          Michael Borbor Level 4
          Hi. What's the compiler error?
          • 2. Re: Get the origin of dispatched Event
            Gregory Lafrance Level 6
            Yeah, I'm wondering what error you're getting as well.
            So how about the following:
            list:Mylist = Mylist(event.currentTarget)
            list:Mylist = event.target as Mylist
            list:Mylist = Mylist(event.target)
            Just trying to come up with possibilities, but can't really say without the error.
            If you just wanted to know which object dispatched the event, if you gave the object a "name" and checked that property, that might do the trick.
            1 person found this helpful
            • 3. Re: Get the origin of dispatched Event
              Barna Biro
              Hi there,
              I think that the only way you can know which project / component triggered the event is to pass along this information when you dispatch the event. I don't think there's a built in something that can help you out with this ( it's really hard to keep track of events, know where they are heading, how's listening for them and where they are comming from ).
              With best regards,
              Barna Biro
              • 4. Re: Get the origin of dispatched Event
                Yeah, because you are already using a custom event, you could have a string static variable to identify the class, or else a non-static string variable referencing another variable, this time an int, that is static you increment in the constructor and concatenate with the non-static variable to idenitfy the instance, then in the event handler, access that custom event property, and you know the class and the instance.
                • 5. Re: Get the origin of dispatched Event
                  drillnaut Level 1
                  Ok folks, after some research , I believe that I have found the solution.  Before I was using simple custom events i.e , dispatchEvent(new Event("dispatchMe")).  However, I think that the better solution is to implement a custom event class which can store the dispatching object as a member variable.  Something like this which I found on the web.
                  package.events
                        public class CustomEvent extends Event
                             public static const CUSTOM_TYPE:String = "customType";
                             public var customProp:String;
                             public function CustomEvent( type:String, cp:String, bubbles:Boolean, cancelable:Boolean )
                                  super( type, bubbles, cancelable )
                                  customProp = cp;
                  Thank you very much for your help and assistance !
                  • 6. Re: Get the origin of dispatched Event
                    drillnaut Level 1
                    That did the trick, thanks
                    • 7. Re: Get the origin of dispatched Event
                      ntsiii Level 3
                      FYI, event.currentTarget.className will return the class of the dispatching object.  If the instance has an id, you can also access that.
                      Tracy
                      • 8. Re: Get the origin of dispatched Event
                        Flex harUI Adobe Employee
                        A nit:  event.currentTarget is probably the dispatching object in this case, but won't always be for bubbling and capture phase handlers.
                        Alex Harui
                        Flex SDK Developer
                        Adobe Systems Inc.
                        Blog: http://blogs.adobe.com/aharui
