Good evevning to the community
I have a web Service thats request information from the database and display the Records in XML
example:
<ArrayOfTitleInfo>
<TitleInfo>
<strTitleName>220276</strTitleName>
<strstore_id>701 </strstore_id>
<strvoucher_id>146003</strvoucher_id>
</TitleInfo>
<TitleInfo>
<strstore_id>702 </strstore_id>
<strvoucher_id>146016</strvoucher_id>
</TitleInfo>
<TitleInfo>
<strstore_id>703 </strstore_id>
<strvoucher_id>146030</strvoucher_id>
</TitleInfo>
</ArrayOfTitleInfo>
I try by this Program to load the Data from The Service but it give me error
Code:
<?xml version="1.0" encoding="utf-8"?>
<mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute"
backgroundGradientColors="[0xFFFFFF, 0xFFFFFF]">
<mx:Script>
<![CDATA[
import mx.controls.Alert;
import mx.rpc.events.FaultEvent;
import mx.rpc.events.ResultEvent;
import mx.rpc.soap.mxml.WebService;
import mx.managers.CursorManager;
* @bindable
* @private
* @property Will hold the data passed from the web service.
[Bindable]
private var _xmlData:XML;
* @private
* Connects and calls the getPlayers() method from our web service.
private function clickHandler(event:MouseEvent):void
CursorManager.setBusyCursor();
event.target.enabled = false;
var service:WebService = new WebService();
service.addEventListener(ResultEvent.RESULT, serviceResultHandler);
service.addEventListener(FaultEvent.FAULT, serviceFaultHandler);
service.loadWSDL("http://www.placespr.com/PLACESPR/placesService2.asmx");
service.GetTitleData();
* @private
* Stores the loaded data in an XML object and displays the DataGrid.
private function serviceResultHandler(event:ResultEvent):void
CursorManager.removeBusyCursor();
_xmlData = XML(event.result);
this.dataGrid.visible = true;
* @private
* Displays any possible errors that might occur when
* trying to connect to our web service.
private function serviceFaultHandler(event:FaultEvent):void
Alert.show(String(event.fault), "Error");
this.loadBtn.enabled = true;
</mx:Script>
<mx:VBox horizontalCenter="0" verticalCenter="0"
horizontalScrollPolicy="off" verticalScrollPolicy="off">
<mx:Button id="loadBtn" label="Load/Display Data" width="700"
click="clickHandler(event);"/>
<mx:DataGrid id="dataGrid" width="100%" height="200"
visible="false" dataProvider="{_xmlData.*}">
<mx:columns>
<mx:DataGridColumn headerText="ID"
dataField="strTitleName" width="30"/>
<mx:DataGridColumn headerText="Name"
dataField="strstore_id" width="120"/>
<mx:DataGridColumn headerText="Score"
dataField="strvoucher_id" width="70"/>
</mx:columns>
</mx:DataGrid>
</mx:VBox>
</mx:Application>
Message Error Box
Thanks in Advance for any help with this problem
evick
Total Likes
What is this "input" referred to in the error message? It does not seem to be in your data, but is there a problem in one of your server side scripts with something called "input"?
Total Likes
Thanks for the Quick Response, its Strange because I have a Web Service Located here and on the output Doesn't include Nothing with the tag <input></input>
The First image of the error are from Internet Explorer, This one came from Mozilla Firefox and are a little different
Location of The Web Service
http://www.placespr.com/PLACESPR/placesService2.asmx?op=GetTitleData
And this is the code in The Web Service
Public Function GetTitleData() As TitleInfo()
Try
'create dataset
Dim dsTitleData As New DataSet
'create connection
Dim objCon As SqlConnection = New SqlConnection(ConfigurationManager.ConnectionStrings("dsn").ConnectionString)
'create data adapter
Dim cmdSQL As SqlDataAdapter = New SqlDataAdapter("SELECT emp_num, store_id, voucher_id FROM voucher", objCon)
'fill dataset using data adapter
cmdSQL.Fill(dsTitleData, "emp_num")
'create object array, using row count as upper dim
Dim objTitles As TitleInfo() = New TitleInfo(dsTitleData.Tables(0).Rows.Count - 1) {}
'loop through dataset to add data to object array
Dim intRsCount As Int16
For intRsCount = 0 To dsTitleData.Tables(0).Rows.Count - 1
objTitles(intRsCount) = New TitleInfo
objTitles(intRsCount).strTitleName = dsTitleData.Tables(0).Rows(intRsCount)("emp_num")
objTitles(intRsCount).strstore_id = dsTitleData.Tables(0).Rows(intRsCount)("store_id")
objTitles(intRsCount).strvoucher_id = dsTitleData.Tables(0).Rows(intRsCount)("voucher_id")
Next
'return object array
Return objTitles
Catch exp As Exception
Throw
End Try
End Function
Thanks for the help
evick
Total Likes
