Good evening to the community,
I finally identified what was the error that explote the data transfer, Now Not show the message error.
What does is load the Datagrid but the data never loads.
If somebody can view the code and help me on identify the possible reason its going to be very appreciated
Flex Code:
<?xml version="1.0" encoding="utf-8"?>
<mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute"
backgroundGradientColors="[0xFFFFFF, 0xFFFFFF]">
<mx:Script>
<![CDATA[
import mx.controls.Alert;
import mx.rpc.events.FaultEvent;
import mx.rpc.events.ResultEvent;
import mx.rpc.soap.mxml.WebService;
import mx.managers.CursorManager;
* @bindable
* @private
* @property Will hold the data passed from the web service.
[Bindable]
private var _xmlData:XML;
* @private
* Connects and calls the getPlayers() method from our web service.
private function clickHandler(event:MouseEvent):void
CursorManager.setBusyCursor();
event.target.enabled = false;
var service:WebService = new WebService();
service.addEventListener(ResultEvent.RESULT, serviceResultHandler);
service.addEventListener(FaultEvent.FAULT, serviceFaultHandler);
service.loadWSDL("http://www.placespr.com/PLACESPR/placesService2.asmx?WSDL");
service.GetTitleData();
* @private
* Stores the loaded data in an XML object and displays the DataGrid.
private function serviceResultHandler(event:ResultEvent):void
CursorManager.removeBusyCursor();
_xmlData = XML(event.result);
this.dataGrid.visible = true;
* @private
* Displays any possible errors that might occur when
* trying to connect to our web service.
private function serviceFaultHandler(event:FaultEvent):void
Alert.show(String(event.fault), "Error");
this.loadBtn.enabled = true;
</mx:Script>
<mx:VBox horizontalCenter="0" verticalCenter="0"
horizontalScrollPolicy="off" verticalScrollPolicy="off">
<mx:Button id="loadBtn" label="Load/Display Data" width="700"
click="clickHandler(event);"/>
<mx:DataGrid id="dataGrid" width="100%" height="200"
visible="false" dataProvider="{_xmlData.*}">
<mx:columns>
<mx:DataGridColumn headerText="ID"
dataField="emp_num" width="30"/>
<mx:DataGridColumn headerText="Name"
dataField="strstore_id" width="120"/>
<mx:DataGridColumn headerText="Score"
dataField="strvoucher_id" width="70"/>
</mx:columns>
</mx:DataGrid>
</mx:VBox>
</mx:Application>
ASP.NET WEB SERVICE:
<%@ WebService Language="VB" Class="placesService2" %>
Imports System.Web
Imports System.Web.Services
Imports System.Web.Services.Protocols
Imports System.Data
Imports System.Data.SqlClient
<WebService(Namespace:="http://placespr.com/")> _
<WebServiceBinding(ConformsTo:=WsiProfiles.BasicProfile1_1)> _
Public Class placesService2
Inherits System.Web.Services.WebService
Public Class TitleInfo
Public strTitleName As String
Public strstore_id As String
Public strvoucher_id As String
End Class
<WebMethod()> _
Public Function GetTitleData() As TitleInfo()
Try
'create dataset
Dim dsTitleData As New DataSet
'create connection
Dim objCon As SqlConnection = New SqlConnection(ConfigurationManager.ConnectionStrings("dsn").ConnectionString)
'create data adapter
Dim cmdSQL As SqlDataAdapter = New SqlDataAdapter("SELECT emp_num, store_id, voucher_id FROM voucher", objCon)
'fill dataset using data adapter
cmdSQL.Fill(dsTitleData, "emp_num")
'create object array, using row count as upper dim
Dim objTitles As TitleInfo() = New TitleInfo(dsTitleData.Tables(0).Rows.Count - 1) {}
'loop through dataset to add data to object array
Dim intRsCount As Int16
For intRsCount = 0 To dsTitleData.Tables(0).Rows.Count - 1
objTitles(intRsCount) = New TitleInfo
objTitles(intRsCount).strTitleName = dsTitleData.Tables(0).Rows(intRsCount)("emp_num")
objTitles(intRsCount).strstore_id = dsTitleData.Tables(0).Rows(intRsCount)("store_id")
objTitles(intRsCount).strvoucher_id = dsTitleData.Tables(0).Rows(intRsCount)("voucher_id")
Next
'return object array
Return objTitles
Catch exp As Exception
Throw
End Try
End Function
End Class
evick
Total Likes
Try tracing the event.result to see if the data is being populated correctly.
Total Likes
