4 Replies Latest reply: May 2, 2009 1:58 PM by dragsternj RSS
    Dreamweaver rewrites path in CSS File
    dragsternj Community Member
      hi
      we are using 2 DW cs4 versions here over the network. When the css file is edited on the second machine it rewrites the path to the images
      from  ../images/content_top.jpg  to
      and so on in the css file.
      the file can than not be saved on the machine its edited on because the css file contains invalid characters ???
      anyone has seen this and has a fix ?
        • 1. Re: Dreamweaver rewrites path in CSS File
          MurraySummers CommunityMVP
          dragsternj wrote:
          hi
          When you say this, do you mean that you are both working on the same local site, which is actually on a remote, shared network drive?
          This is typically what happens when DW thinks that you are either saving the current file outside of the local root folder, or when you are linking to a file that is outside of the local root folder.  What does the site definition for this site look like from each of the two computers (with regard to the path to the local root folder)?  And is that a space between "peter" and "main"?
          Huh?  This is an error you are getting from DW?  We'd need to see the file.  Can you post a link to the page, please.
          • 2. Re: Dreamweaver rewrites path in CSS File
            Hi Murray
            I am running IIS 7 on my machine which serves the files
            i am connecting to the pages on my local drive within the wwwroot folder,
            the other PC connects over the network to the wwwroot folder on my local drive.
            We are doing this since Ultradev. I don't think i ever had these issues before.
            as soon as we save on the remote machine we get the erro massage about the invalid characters
            and the filepath is changed  to this  background-image: url(file://///peter_main/wwwroot/netelo/images/bg_tile.jpg)
            The website/files are in its early stages and i have no live examples but will provide a screenshot of the error message if its helpful.
            Pete
            • 3. Re: Dreamweaver rewrites path in CSS File
              Screenshots don't help.  The only way to diagnose something like this is to see the actual code.
              Is your colleague using a mapped drive for your local drive, or are they coming in via a network name?  If the latter, try the former.
              I share my files around my net just the way you are, but in my case, it's always via a mapped drive letter, not a computer name.  I have never had this kind of problem - and I'm pretty sure that it's happening to you because of the way your colleague is getting to the drive.
              • 4. Re: Dreamweaver rewrites path in CSS File
                I "ivestigated" this a little further
                it not happens on one site definition, but all. i tried mapping the drive to a driveletter, same result.
                dreamweaver cs4 changes the path to all attachments  in the stylesheet from
                #header {
                    height: 128px;
                    width: 890px;
                    margin-right: auto;
                    margin-left: auto;
                    background-image: url(images/header.gif);
                #header {
                    height: 128px;
                    width: 890px;
                    margin-right: auto;
                    margin-left: auto;
                    background-image: url(file://///peter_main/wwwroot/doorhardware/images/header.gif);
                upon saving i get the attached error message
                This only happens if i save the file css from within the htnl design view. If i make a change to the css file and i save the css file alone it doesn't rewrite the code. If i make a change to the css file from within the css inspector and save the html page without saving the css file first, the code will be rewritten to above.
                i tried the same site definitions in Dreamweaver CS3 and there is no error  everythings fine. No path changed if changes made to the css file.
                Looks like a bug.
