I am calling a web service using Actionscript. I receive no errors during the call and when I view a trace using <mx:TraceTarget/> I see the request is being issued correctly and the response is being returned correctly. In the trace, the result is formatted simply as a string but has all of the correct tags and data.
When I try and assign the data in the structure of the event.result.whatever to responseXML (see below), I get the dreaded Error #1009: Cannot access a property or method of a null object reference. (I'm using 'whatever' here just as a placeholder for the actual structure elements which the Content Assist finds just fine in design time) The errors are runtime only. Using Alerts.show to check, indeed, the variable has a null value. I am instantiating the variable that catches the result similar to:
[Bindable]
Private var responseXML:XML;
private function wsHandler(event:ResultEvent):void{
XML(event.result.whatever);
I've tried just about every conceivable syntax, type, etc. that I can think of.
Two questions...
Any suggestions how to actually fix this so that I can get access to the data?
How can you access the information presented in the trace programatically?
Thanks very much...
Total Likes
Could you post a bit of the trace data?
Total Likes
Here is the result showing good data originally in a single string, not broken into XML tags of course... The structure corresponds to the expected WSDL definition.
Encoded SOAP response
<?xml version="1.0" encoding="UTF-8"?>
<soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:ns1="urn:dustyIMSTNS">
<soap:Body>
<getIMSStuffResponse xmlns="urn:dustyIMSTNS">
<imsprogramout>
<imsProgramOut>
<outputData>
<outDataType>
<outLastName>BROWN</outLastName>
<outFirstName>GEORGE</outFirstName>
<outExtension>00000000</outExtension>
<outZipCode>75225</outZipCode>
</outDataType>
</outputData>
</imsProgramOut>
</imsprogramout>
</getIMSStuffResponse>
</soap:Body>
</soap:Envelope>
Thanks for your interest in helping...
Total Likes
