We ran into the same problem with RH7 people have described here the other day. And yes, it had to do with rowspans in tables in combination with conditional build tags. Maybe the problems was only partially fixed for RH7. It seems to definitely exist in certain situations. When compiling the project, the compiler searches for instances of conditional build tags, and during the process "stumbles" about code that has too many <tr> tags. I guess that the code that was created in this topic had been created with RH X5 and that RH7 would no longer create this type of faulty code. Anyway, here is how we located the problem, hopefully this may help anyone in the future. I'm sorry that the description is very short but I didn't do this myself, so I don't have any more details:
- Used Sysinternals' FileMonitor or ProcessMonitor to identify the HTML file that was processed by RoboHtml.exe when it stopped working
- Used an HTML editor to remove those rows of a table in the document that belonged to a rowspan. (We had td rowspan=5, and therefore removed five <tr>...</tr> sections): Then, it compiled.
- Removed rowspan, and replaced corresponding <td_null> by <td></td>. Then, it compiled.
The most important step is to locate the corrupt topic. There are probably multiple ways to "fix" the table/rowspan problem. It's possible that recreating the table with RH7 would be enough to fix it.
TWSisters
