Hello to all,
I'm connecting a flex application via xml to a php server.
Because of the response can spent a lot of time ...as 1:00 minute per consult, I would like to show a progress bar while the application is receiving data.
It´s not possible with httpservice, that only throw the result event when the complete information is received.
I´ve tried with urlstream class that have the progress event...but it only work with a static file to download...
It doesn´t work like a service with a buffer that is progressively being filled by the php server.
I´ll apreciate your suggestion, Thanks.
Total Likes
You could popup a progressbar when the request is made, and then close the progressbar in the result handler.
Total Likes
Thanks Greg,
It can be a solution, a progressbar going to to the beggining and to the end until the result is completed, but I´m afraid the user can feel the same as "show busy cursor = true " while he is waiting. So he can think the aplication is hung up.
Because I can´t know how long it takes, I can´t determinate the percent received information of the completed response.
Is for that I thought in a label number being increase with the bytes received would be a real representation of the actual progress.
Ana
Total Likes
Even I am facing a similar issue where I would like to show a progressbar which displays the actual progress of an httpservice and not just a busy cursor. I have tried adding an event listener to the httpservice 'progress event' but it doesnt seem to be called at all. Could anyone please give any pointers to this ?
Thanks in Advance
Amul
Total Likes
Likes
