When using CS3 Master Collection (on Mac 10.5.6) I could use Quicktime or Apple Compressor (uses QT) to export .mov files to .flv files. Then I upgraded to CS4 Master Collection and everything still worked. Then I got tired of having all the CS3 programs still on my computer so I used the CS3 disc to uninstall CS3. Later I noticed the Flash export within Quicktime was gone. So I put back CS3 install disc and just installed the Flash export components and then the .flv export was back on Quicktime. Though I solved the problem, shouldn't CS4 (upgrade) have that plugin as well? Did I do something wrong? Are other things going to be missing or go wrong since I uninstalled CS3? Let me know what you think. Thanks
