Related to the post in this forum:
http://www.adobe.com/cfusion/webforums/forum/messageview.cfm?forumid=1&catid=7&threadid=1386433&high...
The problem is that ColdFusion 8.0.1 changes the case for
namespaces of custom datatypes. This breaks the implementation of
the webservice in other languages that are case sensitive. (like
.NET). Because of this error, we cannot update the servers to fix
other critical bugs in the 8.0.1 release.
Unable to find a solution ;-(, I'm trying to find a
work-around for this problem. I thought I had it; I would save the
generated WSDL document generated by Coldfusion 8.0.1 and correct
the case manually. Then using the corrected WSDL file as an
external WSDL file. The problem is that when I would use the
generated WSDL file in the component I get an AXIS error.
It also generates this error when I don't use an external
WSDL file, but use a custom namespace to the webservice url. Like:
http://mydomain.com/soap/webservice.cfc?wsdl
This is the error I get:
AXIS error
Sorry, something seems to have gone wrong... here are the
details:
Fault - Error attempting to create Java skeleton for CFC web
service.; nested exception is:
coldfusion.xml.rpc.CFCInvocationException:
[java.lang.ExceptionInInitializerError :
null][java.lang.ClassCastException : [Ljava.lang.Object; cannot be
cast to java.lang.String]
I've read on forums that this is a mapping problem. I
currently do have a mapping, but removing this didn't fix the
problem.
Does anybody have any ideas on how to solve this?
Maybe downgrade AXIS?, so the generated WSDL file would be
the correct case as with version 8.0.0
