Is overloading is possible in coldfuion?
yes
Thanks dan,
How many arguments it will support.I guess it has limitation .
How many actual arguments it supports and how many optinal parameters it supports.
I interpreted the original question as, "is it possible to overload Cold Fusion and get it to stop working?". Apparently, that was not the correct interpretation.
Definitively can happen, as with a any other server if you put too
much burden it'll begin to deny request and eventually crash that's
why CF has a load balancing software that you can use when you cluster
servers.
Sincerely,
Michael
ColdFusion does not support function overloading.
That may be a 'Not Yet'. IIRC ColdFusion 9, currently in early testing, may support method|function overloading.
That would be a sweet feature. But I guess we will have to wait and see.
oh i dunno, it's typeless so anything goes with argument datatypes & i suppose
if you used argumentCollection even the number of arguments could be handled.
Thanks all,
I tried with example and found that it only allows 3 arguments as actual parameters and after that it is taken as optional parameters.
