1. Re: Bridge CS4 - Image processing into subfolders
Paul Riggott May 9, 2009 1:45 PM (in response to Petrula)This is a job for Photoshop not Bridge, Bridge can not alter the JPEG settings.
This Photoshop script should do what you want if you are talking about normal JPEGS and not Save for Web.
#target photoshop
var imageFolder = Folder.selectDialog("Select the folder with JPGs to process " + $.getenv("username"));
var quality = prompt("PLease enter quality required 1-12 ",5);
if (imageFolder != null) processFolder(imageFolder);
function processFolder(folder) {
var fileList = folder.getFiles()
for (var i = 0; i < fileList.length; i++) {
var file = fileList[i];
if (file instanceof File && file.name.match(/\.jpg$/i)) {
open(file);
saveFile(quality);
app.activeDocument.close(SaveOptions.DONOTSAVECHANGES);
} else
if (file instanceof Folder) {
processFolder(file);
function saveFile(quality){
saveOptions = new JPEGSaveOptions();
saveOptions.embedColorProfile = true;
saveOptions.formatOptions = FormatOptions.STANDARDBASELINE;
saveOptions.matte = MatteType.NONE;
saveOptions.quality = quality;
var fileRef = new File(decodeURI(activeDocument.fullName.fsName));
activeDocument.saveAs(fileRef,saveOptions);
2. Re: Bridge CS4 - Image processing into subfolders
Zeno Bokor May 9, 2009 11:54 PM (in response to Petrula)When choosing that command from Bridge it will only work on the selected files so you have to either view all the files from the subfolders by going to View->Show Items from Subfolders and then selecting all the images or by choosing the command from Photoshop as then you can select a folder which you want to process and it also gives you the option to process all the subfolders
