1. Re: Photoshop Won't Open-Help!!
John Joslin May 9, 2009 10:31 PM (in response to mikeobe)Try resetting your preferences as described in the FAQ.
http://www.adobeforums.com/webx/.ef4a07f/1
You either have to physically delete (or rename) the preference files or, if using the Alt, Ctrl, and Shift method, be sure that you get a confirmation dialog.
This resets all settings in Photoshop to factory defaults.
A complete uninstall/re-install will not affect the preferences and a corrupt file there may be causing the problem.
3. Re: Photoshop Won't Open-Help!!
John Joslin May 10, 2009 12:46 AM (in response to Zeno Bokor)Zeno Bokor wrote:
check your links
Here's the correct link: http://forums.adobe.com/thread/375776?tstart=0
Huh!
I was on my netbook where the boilerplate links are the old ones.
Thanks for pointing that out!
4. Re: Photoshop Won't Open-Help!!
Mylenium May 10, 2009 5:17 AM (in response to mikeobe)Did it ever even launch? If it never started to begin with, the prefs should not be affected and it's most likely a more generic issue. Therefore please provide info about your hardware (processor, graphics card) and operating system.
Mylenium
5. Re: Photoshop Won't Open-Help!!
mikeobe May 10, 2009 5:56 AM (in response to John Joslin)First of all, A great big thanks to John and Mylineum, well, Photoshop has opened, haven't tried anything yet, but a Major accomplishment! Now I need to see if I can get a Two Fer, Having the same problem with Bridge and Lightroom is acting kinda funky as well! Is is the same procedure?
Thanks again,
Mike
PS: I know just enough about this stuff to get me in Trouble!!:)
6. Re: Photoshop Won't Open-Help!!
For Bridge hold down the Ctrl key as you double-click the icon and hold it down till you get a reset dialog.
Lightroom have their own forum.
7. Re: Photoshop Won't Open-Help!!
mikeobe May 10, 2009 6:58 AM (in response to John Joslin)Thanks, the reset dialog came up but Bridge still did not open, I'm going to reboot and see if that works? I have ESET Anti Virus, wonder if that could be causing a problem? I've seen in here where that has contributed to peoples' problems? I'll let you know how the reboot goes! Thanks again!
8. Re: Photoshop Won't Open-Help!!
mikeobe May 10, 2009 7:50 AM (in response to John Joslin)Well, the reboot didn't work and also uninstalled my virus program, nuttin! I'm wondering If I shouldn't start over, uninstall CS4 and start over again?
9. Re: Photoshop Won't Open-Help!!
If you do, make sure to run the Adobe Clean script after the un-install.
10. Re: Photoshop Won't Open-Help!!
mikeobe May 10, 2009 4:28 PM (in response to John Joslin)Thanks again, John! I haven't uninstalled CS4 yet, with my screwing around I've corrupted windows, so recovering my computer with my last Norton Update!
I will make sure and use the clean script!
I would be in big trouble without your and others help!
