I can't figure this out. I'm using Captivate 4 and the application I'm recording shows a table with some entries. Some of the lines on the tables - clearly visible in the interface - are not being captured. See attached example. I've tried changing the size of the recording window and it doesn't help. This isn't a 'show stopper' but it does look kind of sloppy. Any ideas? Thanks!
Hi there
Do they show when you preview and in the editor? What happens if you experiment with different Slide Quality settings? Right-click the slide in the Film Strip and choose Video Quality to configure it easily.
Cheers... Rick
Hi there
Cheers... Rick
Many thanks to Captiv8r. I changed the video quality from High to Optimized and this completely solved the problem. I would never have figured this out on my own.
